what would cause a t2 on fiesta to over boost
Old Jul 18, 2008 | 08:12 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default what would cause a t2 on fiesta to over boost
had actuator set with half the hole pulled over the turbo rod like u r ment to and it boosts of the gauge. thought it might be the boost solidoid so i removed it and run vacume straight from turbo to actuator and still the same. Then brought a msd -31 and still does same thing. I have to run the actuator about a hole lenght past the turbo rod and the car now runs about .7 bar but is well laggy.
Any ideas cheers
Old Jul 18, 2008 | 08:25 PM
ASHCOSSIE's Avatar
ASHCOSSIE
anyone
Old Jul 18, 2008 | 08:39 PM
gup's Avatar
gup
have you plugged the solonoid (spelling) back in
Old Jul 18, 2008 | 08:48 PM
ASHCOSSIE's Avatar
ASHCOSSIE
yer but no pipes run to it now
Old Jul 18, 2008 | 08:51 PM
gup's Avatar
gup
you might need to plum it all back in
how much boost do you wanna run tho
Old Jul 18, 2008 | 08:53 PM
ASHCOSSIE's Avatar
ASHCOSSIE
the car running stage 1 on the shit management not the ofab one. I picked the car up a couple of weeks ago and this problem was allready there and i disconneted the boost solidoid trying to fix it
Old Jul 18, 2008 | 10:30 PM
ASHCOSSIE's Avatar
ASHCOSSIE
help
Old Jul 19, 2008 | 05:06 PM
ASHCOSSIE's Avatar
ASHCOSSIE
no ideas?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Steve Escos
Oct 1, 2015 06:57 AM
Russ Payne
Sep 25, 2015 08:29 PM
