Removing Modine?
Old Jul 18, 2008 | 04:22 PM
Paul_RS's Avatar
Paul_RS
Default Removing Modine?
Firstly i'd like to confirm i'm calling this part the right name
Its the standard oil cooler jobbie that has two water pipes going into it, sits between the oil filter and the block on a yb?
Now if i take this out to put a mocal oil cooler in, can i just reroute the original water pipe that goes into it? IE instead of going into modine then the head, can i just go straight to the head, bypassing the modine part?
Thanks in advance
Old Jul 18, 2008 | 04:37 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thats fine
Steve.
Old Jul 18, 2008 | 04:41 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the modine is actually very good though, as it helps to warm the oil up to temp from cold, i wouldnt want to remove it tbh...
Old Jul 18, 2008 | 04:46 PM
Paul_RS's Avatar
Paul_RS
I know, but i want to fit a gauge adaptor as i have some wunder plumbing for my oil temp and pressure gauges lol. I already have an oil cooler take off at the end of the 4x4 extension arm, so thats the onlt place i can put the gauge take off.
Originally Posted by cossie4i
Thats fine
Steve.
Old Jul 18, 2008 | 04:57 PM
JTECH James
Passion for Fords!
imo reducing engine wear would be more important,
oil temp should be from sump, and adaptors are available to fit pressure sensors in the block
goodluck anyway
Old Jul 18, 2008 | 05:12 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Leave it alone. It is as efficient as a 13 row oil cooler!! And it heats up your oil a lot quicker reducing engine wear as said above.
Old Jul 18, 2008 | 05:54 PM
Paul_RS's Avatar
Paul_RS
goodluck anyway
I have the temp sender in the sump at the moment and the pressure from the oil pressure switch takeoff, its just a bit untidy for my liking lol.
But if removing the modine is going to cause damage i think i'll stick with what i've got.
Got a statted mocal sandwich plate on order too as my car always ran cold witht he non stat plate.
Cheers guys!
Old Jul 18, 2008 | 06:04 PM
JTECH James
Passion for Fords!
i got the stat mocal cooler aswell, seems good!
Old Jul 18, 2008 | 06:06 PM
rsnissan's Avatar
rsnissan
even with my stat sandwich plate (and a bigwing) my oil ran too cold, just fitting the modine back as as i type......well after I type lol
Old Jul 18, 2008 | 06:10 PM
Paul_RS's Avatar
Paul_RS
So a stat cooler and the modine should see me ok temp wise for road use?
What do you reckon abouit using a 2wd filter to give me clearance to fit the gauge takeoff at the end of the filter extension arm?
Old Jul 18, 2008 | 08:39 PM
Paul_RS's Avatar
Paul_RS
bumpage
yes i am an impatient cunt
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
