Which turbo timer for 4x4 cossie?
Old Jul 18, 2008 | 01:48 PM
rog's Avatar
rog
Default Which turbo timer for 4x4 cossie?
Tried the search option but didn't really find anything of much help, anyone give me some suggestions on which brand and how to fit?
Old Jul 18, 2008 | 01:49 PM
KSA-Cossie's Avatar
KSA-Cossie
Waste of money m8.
Old Jul 18, 2008 | 02:29 PM
Kverna's Avatar
Kverna
Virgin-popper
Greddy or apexi ones are good
Old Jul 18, 2008 | 02:45 PM
Franco's Avatar
Franco
I had one fitted to the escort via the clifford alarm, seems ok and would let it cool down after thrashing it.
Whether its good or bad, you'd have to speak to an expert!
Old Jul 18, 2008 | 03:05 PM
Oranoco's Avatar
Oranoco
Just don't drive like a twonk for the last 5 miles home. You can then spend the money on something to make the car faster instead
Old Jul 18, 2008 | 03:24 PM
AlexRS2782's Avatar
AlexRS2782
Not worth the money imo & in some cases can invalidate your insurance by having one fitted/working on the car
Just drive off boost for the last couple of miles of your journey and/or let the car idle for a minute or 2 when you get home - does the same job as a timer & it wont cost you the £££ that can be better spent on something else
Old Jul 18, 2008 | 03:29 PM
Kverna's Avatar
Kverna
Virgin-popper
Agreed, but someone who are always in a hurry - can be better off fitting one
Old Jul 18, 2008 | 03:40 PM
xr4x4rs's Avatar
xr4x4rs
ive heard its classed as hot wiring so the police can actually do you for 1 having the car running with no one in it, and 2 for being able to have the car running with a key in the igntion, even though its only for a short period of time
for tehe sake of driving sensibly and ticking over for a minute or 2 its not really worth the money
Old Jul 18, 2008 | 03:45 PM
Oranoco's Avatar
Oranoco
Having the engine running without you in or with it is actually an offense in its own right. Can't remember what it's called though.
Old Jul 18, 2008 | 03:46 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
yep, it is illegal
Old Jul 18, 2008 | 04:22 PM
smerth54's Avatar
smerth54
what a stupid offense cant we do anything in this country without
it being illegal next thing you know it will b illegal to talk or something stupid
Old Jul 18, 2008 | 04:29 PM
Oranoco's Avatar
Oranoco
I thought it was pretty valid really as to be fair it was made law prior to turbo timers being on the scene.
Old Jul 18, 2008 | 04:37 PM
AlexRS2782's Avatar
AlexRS2782
Yeah its always a good idea to leave your engine running while you're not with your car - as one of the directors at my old place of work found when someone helped themselves to his Mercedes when he did just that
Old Jul 18, 2008 | 06:10 PM
It is an offence to leave your car unattended, with the engine running, or incidentally with the headlights on.
The engine running stems from the war when enemies could make immediate use of transport if they found a running vehicle.
Some ecu's have a built in turbo timer you can activate, plod cars have "RUN LOCK" whereby the engine will run constantly but if you try to drive without deactivating run lock it cuts out.
Old Jul 18, 2008 | 06:27 PM
pani_k's Avatar
pani_k
PassionFORD Member
Also, if you have an alarm system fitted, it may not work with it. I don't know if alarm systems will arm their sensors and immobilize immediately after the timer has stopped or you have to do it yourself. Either way, driving off boost for 5 or so minutes before your journey ends or waiting a minute after you have arrived at your destination is good enough.
Old Jul 18, 2008 | 06:42 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Offence is called Idling I am led to believe.
Pretty sure it only applies on a public highway though.
Tim
big_Rad
Sep 15, 2017 09:36 AM
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
frug
Aug 26, 2015 06:46 PM
IAN RS2k
Aug 18, 2015 07:51 PM
