escos banana pod gauges ilummination problem
bought a set of these for my escort van as already had pod ive looked on the back and there is place for two plugs a two pin and one five pin maybe six but anyway the two pin i beleive is illumination but doesnt illuminate when given a pos and neg wondered if this is a fault as bought them from fleabay any help will be great
http://www.litewave.co.uk/glow_wire.asp
scroll down to
12v Glow Wire Inverter, no Glow Wire: £13
Thats what you need mate, connect the feed to the box (cig lighter end - make sure you get the pos and neg right) to the illumination feed from one of the dash switches i.e. fog or heated rear screen (normally the top single wire on the switch) and the other to an earth.
The output end to the pins 1 & 2 on the pod (doesn't matter which way round these go as it's AC from there)
job done!!
ps. I'm assuming you have a mk5 van!!
scroll down to
job done!!
