is this correct
Old Jul 15, 2008 | 07:44 PM
Smartdj.'s Avatar
Smartdj.
Exclamation is this correct
please see pic on the left....
Old Jul 15, 2008 | 07:54 PM
sortedsaff's Avatar
sortedsaff
from that pic and alot of squinting it looks to be . but get bigger pic for 100% answer matey
Old Jul 15, 2008 | 07:55 PM
FMC's Avatar
FMC
Excluded from FocusSToc
i knew i should ave gone to specsavers!
i can't tell wtf is wrong there lol!
Old Jul 15, 2008 | 08:19 PM
Smartdj.'s Avatar
Smartdj.
Old Jul 15, 2008 | 08:20 PM
Smartdj.'s Avatar
Smartdj.
im sure the gasket is the wrong one???????????
Old Jul 15, 2008 | 08:22 PM
Smartdj.'s Avatar
Smartdj.
clearly it all needs a good old clean up
Old Jul 15, 2008 | 10:04 PM
mk3cab's Avatar
mk3cab
is that the 1.9 engine build mate
Old Jul 15, 2008 | 10:11 PM
Smartdj.'s Avatar
Smartdj.
its suposed to be
Old Jul 15, 2008 | 10:13 PM
mk3cab's Avatar
mk3cab
yeah it looks like it from the pistons, what head gasket you ordered that also looks like the ones they use on the 2.1 zetec turbos
Old Jul 15, 2008 | 10:18 PM
Smartdj.'s Avatar
Smartdj.
the head gasket is the cvh1.9---1.6 felpro......but it looks wrong to me (water ways)
Old Jul 15, 2008 | 10:23 PM
mk3cab's Avatar
mk3cab
the only thing to me that looks difference is the size of the compression rings which dont matter anyway, felpro make superb gaskets i wouldn't be to concerned about it. have you had the pistons out?
Old Jul 15, 2008 | 10:27 PM
Smartdj.'s Avatar
Smartdj.
no..it came out of a running enginge so im not that fused (mates car) ...do u think its worth a look .all the bores look cool..u think it all looks ok then...surely them waterways shouldnt be like that
Old Jul 15, 2008 | 10:33 PM
Smartdj.'s Avatar
Smartdj.
i think bottomend was made by either volcan engeniring or ...........engine specialist ,,,,,volcan i think
Old Jul 15, 2008 | 10:36 PM
mk3cab's Avatar
mk3cab
what you mean about the waterways dont understand exactly if you mean they are bigger holes under the gasket thats how they are mate. the pistons look like they have det at the back of the piston mine was like that and had had damaged the piston quite bad and lost 2bar compression, every time i went into boost it blew the oil cap off.
Old Jul 15, 2008 | 10:37 PM
Smartdj.'s Avatar
Smartdj.
do u mean the clean patch at the bk
Old Jul 15, 2008 | 10:40 PM
mk3cab's Avatar
mk3cab
yeah its getting hot
Old Jul 15, 2008 | 10:41 PM
Smartdj.'s Avatar
Smartdj.
omg its guna be a chamber of horrors underneath....lol.....i wouldnt be suprised........rings look coolthough
Old Jul 15, 2008 | 10:44 PM
mk3cab's Avatar
mk3cab
did you see the engine running?
Old Jul 15, 2008 | 10:49 PM
Smartdj.'s Avatar
Smartdj.
naah he broke the car because of rot aparently... ........ the shell was rotten though
Old Jul 15, 2008 | 10:55 PM
mk3cab's Avatar
mk3cab
if you decide to take them out and look i can send you a pic of mine and also have some spare so you can replace any nackered ones.
Old Jul 15, 2008 | 10:58 PM
Smartdj.'s Avatar
Smartdj.
really that would be amazing ...ill see what my mate says who puting the engine in 4 me....thanks 4 your help m8 ill keep u in mind
Old Jul 16, 2008 | 07:12 PM
Smartdj.'s Avatar
Smartdj.
what makes an engine "det"folks.....is it to much boost for the amout of fuel
Old Jul 17, 2008 | 04:18 PM
mk3cab's Avatar
mk3cab
yeah plus the timing could be to advanced so instead of the spark igniting the fuel it ignits itself under pressure. air temps can also make it det if to hot. ect
Old Jul 17, 2008 | 06:03 PM
Smartdj.'s Avatar
Smartdj.
when we striped the head fron the block..the cam pulley was directly on the centre of the ajuster..not ajusted either way..he had a frontcooler as well..aparently he had a turbo shiped over fron the states...it was a mothership(saw that on his old engine)....that festa was quick as fuck!!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
Fiddy
21
Sep 29, 2015 06:10 PM
RSmark84
Sep 13, 2015 01:29 PM
