Remove transfer shaft from 2wd cossie
Old Jul 14, 2008 | 10:09 PM
Thanasis's Avatar
Thanasis
Default Remove transfer shaft from 2wd cossie
Hello everybody,can anyone explain how can to remove the transfer shafts from 2wd rear diff?
thanks a lot
Thanasis
Old Jul 15, 2008 | 05:26 PM
cossie604's Avatar
cossie604
Do yor mean the out put flanges on the diff? If so, then its dead easy! Remove the back plate, rotate the diff until you can see the sun and planets and you'll see the two big C cips that are holding the flanges in place...I find the easiest way to remove these is with two good sized flat blades screwdrivers and just push both sides of the clip down at the same time.
Old Jul 16, 2008 | 11:55 AM
Thanasis's Avatar
Thanasis
Many thanks my friend,
Regards
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 29, 2015 08:16 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
lockie
Jul 31, 2015 10:03 PM
