idle control valve
Just make sure it is up to temp, and fans etc off, disconnect iscv, then on 4wd just turn, on 2wd you need a spanner as well as a small stubby screwdriver as they have a locknut around screw.
pretty good mate,it only does it sometimes idels just over 1000k it started once i put the cone filter on.
not had it unplugged yet mate.
where is it located on the sapph?
on top of the throttle housing,will have a grey top!if u not sure where that throttle housing is just follow the throttle cable to the inlet manifold you will see it there,the adjustment screw is on the throttle body but at the bottom of it!u need to get the engine hot unplug the iscv then adjust the idle speed via the adjustment screw to around 800rpm then reconnect the iscv if you got it set up right the idle speed should not move
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
