Handbrake light stuck on after a job
Another silly one no doubt!! Just changed a rear caliper and has to loosen the handbrake cable to release it etc. Its now set pretty much right (4-5 clicks) but the dash warning light is stuck on - could this just be a dodgy switch or am I being stupid about something here??
And where is the darn switch located???
I would deplete the pressure in the braking system by pressing about 15 times with engine off and key out, then when you re-insert the key you will hear it pressurising, it should slow down the sound just as the abs light and h/brake liught go out as the pump reaches pressure.
Sometimes they can get a bit sticky, just turn on off a few times can often help.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
i've had that before.
