rs turbo into my mk3....
Old Jul 10, 2008 | 10:36 PM
nickscunny's Avatar
nickscunny
Default rs turbo into my mk3....
Not a great deal of experience in engine conversions but im managing, however.....
Im in middle of dropping a series 2 rs turbo engine in my mk3 cabriolet and im having trouble because it sits on the piss. Its slightly lower at drivers side. I bought brand new engine mounts for them (mk3, central mounted inner wheel arch bolt hole) and still no joy. Tried the mk4 mount and it sat even more on the piss and the inner hole didnt line up under wheel arch. When i ordered the mount i was told theres 3 different mounts involving the inner wheel arch bolt hole. One mounted central, one slightly to left and one slightly to right. The RST one he told me was central, so he sent it, now it sits on the piss.....
also anyone got a picture of the right mount?
Old Jul 10, 2008 | 10:43 PM
mk3cab's Avatar
mk3cab
are you sure its the engine mount and not a gearbox mount on wrong? i did this
Old Jul 10, 2008 | 10:46 PM
nickscunny's Avatar
nickscunny
the gearbox was the one straight off my mk3 from my zetec conversion, i basically took the box off my zetec when i removed it from my mk3 and bolted it to my turbo engine.
Old Jul 10, 2008 | 10:51 PM
mk3cab's Avatar
mk3cab
the steel part of the engine mount chane between the mk4 and mk3 in looks but dont know if they change the way the engine fits, just a thought
matt c
Old Jul 10, 2008 | 10:54 PM
nickscunny's Avatar
nickscunny
cheers mate, i shall go back to the garage tomorrow and figure something out lol....
Old Jul 10, 2008 | 11:48 PM
Mr.T's Avatar
Mr.T
Does it sits like this?
Old Jul 11, 2008 | 01:03 AM
nickscunny's Avatar
nickscunny
yes mate exactly like that......
Old Jul 11, 2008 | 01:04 AM
cabrio boy's Avatar
cabrio boy
wrong mounts i found that out too when i did my last one !!
Old Jul 11, 2008 | 01:05 AM
Mr.T's Avatar
Mr.T
Then you have the wrong mount. There are 2 mounts that look exactly the same but somehow they are still different hehe. Stupidly enough i didn't take pics of the mounts. So can't help you on that. Just change the mount.
Old Jul 11, 2008 | 01:06 AM
nickscunny's Avatar
nickscunny
cant see it very well and the engine crane is taking the strain...
Old Jul 11, 2008 | 01:08 AM
nickscunny's Avatar
nickscunny
i shall order all the mounts available from the supplier and see which on fits the best and send the rest back...... pain in the backside......
Old Jul 11, 2008 | 01:11 AM
cabrio boy's Avatar
cabrio boy
always mate !!
Old Jul 11, 2008 | 01:16 AM
Mr.T's Avatar
Mr.T
It took me until the 3th mount before i found out what it did wrong. It was cold and no heating. I did al 3 mounts 1 one evening <real tears
Old Jul 11, 2008 | 01:17 AM
nickscunny's Avatar
nickscunny
i know the feeling i have fitted 3 tonight trying to figure it out, the zetec conversion mount, the mk4 rst mount that came with the engine and a brand new mk3 mount. Im getting fed up with it
Old Jul 12, 2008 | 05:00 PM
nickscunny's Avatar
nickscunny
bit of an update, it was the engine mounting cage that needed changing. Mk4 escorts have different ones to the mk3. Problem sorted, i borrowed one from a mk3 xr3i. I shall have to put one back asap.
Anyway, engines in, shafts are in, just gotta bolt the rest of the anti-rollbar and connect everything up.....
Old Jul 12, 2008 | 05:20 PM
Mr.T's Avatar
Mr.T
ok good one mate. Good luck with it
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
