exhaust gas temp gauges..
Old Jul 10, 2008 | 01:07 PM
R5FORD's Avatar
R5FORD
Default exhaust gas temp gauges..
can someone tell me what the point of one is?? not like you can change the temp isit?
Old Jul 10, 2008 | 01:08 PM
Garage19's Avatar
Garage19
You can if you have a mappable ecu.
Old Jul 10, 2008 | 01:10 PM
R5FORD's Avatar
R5FORD
o right.. it hought people just had the gauges for show
rsnissan's Avatar
rsnissan
will tell you if the cars running lean (say something fails ) also an idea if you run ALS on a non maram shafted turbo maybe
Old Jul 10, 2008 | 01:11 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Modified turbo cars don't like to be held flat out for long periods of time, so an EGT gauge will give you can indication of when to call it day and come off the throttle, thus preventing a molten mess of the engine .
If you drive like a girl though, then not really needed.
Old Jul 10, 2008 | 01:15 PM
R5FORD's Avatar
R5FORD
so i wont need one then
il stick to my boost,water and oil temp, fuel and oil pressure
Old Jul 10, 2008 | 01:22 PM
Mike Rainbird
Caraholic
Yes, that was my inference .
Old Jul 10, 2008 | 01:27 PM
R5FORD's Avatar
R5FORD
Old Jul 10, 2008 | 01:34 PM
Porkie's Avatar
Porkie
I never look at mine.... whats a level to start backing off at?!?!?!
Old Jul 10, 2008 | 01:36 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Just before it melts Lee
Steve
Old Jul 10, 2008 | 01:48 PM
Mike Rainbird
Caraholic
On a Cossie, I would not want it to go above 900°C on a flat out run.
Old Jul 10, 2008 | 01:57 PM
Porkie's Avatar
Porkie
and on track?
Old Jul 10, 2008 | 01:59 PM
rsnissan's Avatar
rsnissan
anywhere held i'd expect (probably more to do with high speeds)
Old Jul 10, 2008 | 02:02 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
it's to tell you what the egt is
you have a water temp guage and oil pressure guage but you can do fuck all about what they say too lol
Old Jul 10, 2008 | 02:05 PM
Garage19's Avatar
Garage19
Change the thermostat, fit a bigger rad/header tank, change the oil pump, rebuild a worn engine.
R5FORD's Avatar
R5FORD
yh but they have more of a reason.. if your water is getting to high you wonder why.. same as if your pressures droping.
i know its the same principle with the EGT but how can this be changed?? i know not driving flat out would help
Old Jul 10, 2008 | 02:16 PM
Turbosystems
Super Moderator
high egt throttle off immediately much cheaper than a rebuild
Old Jul 10, 2008 | 02:18 PM
Mike1's Avatar
Mike1
Jay B had one on his Escos and IIRC I think it might have saved his engine once at Combe - can't remember what pipe exactly came off but a rising reading on the EGT gauge is what alerted him and made him abort that particular session
Old Jul 10, 2008 | 02:23 PM
Mike Rainbird
Caraholic
Originally Posted by Porkie
and on track?
Depends, I have seen as high as 1150°C with the ALS on .
Because of the sustained use of the throttle on track, the EGTs can creap a little higher due to heat build up.
What have you seen?
Old Jul 10, 2008 | 07:06 PM
The BEST advantage is gained from a decent ecu, this will SAVE your engine as it can be set to AUTOMATICALLY back off the power if EGT goes too high.
Also useful as a tuning tool, as a given state of tune/parts will give a certain "correct" temp, if it goes off this but not dangerously so you know you have a problem like a dicky lambda etc, or whatever it is, as temp will stay fairly stable under normal use.
Only £115 NEW(audi), but how many ecu's can use them ?, fortunately my one does.
Old Jul 10, 2008 | 07:15 PM
Mike Rainbird
Caraholic
Red face
Fine for a road car, but the temps would creep up higher on track to beyond the normal trigger point and would back off power when the fuelling was spot on, but it was only the heat build up from continuous flat out driving that was causing the high temps. Also, it would depend on how the power was backed off, as it would have to back the boost off, as retarding the ignition would just exasperate the EGT issues....
Old Jul 10, 2008 | 07:17 PM
Alg1k's Avatar
Alg1k
I see about 800 deg on a flat out run in the down pipe and regularly see 900 in the ex manifold primaries
Old Jul 10, 2008 | 07:18 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
What have you seen?
I'm guessing Lee don't know
Old Jul 10, 2008 | 07:19 PM
The whole point of the egt is you CAN find the safe max load power wise, bit irrelevant as shonky w/m don't do it anyway.
Old Jul 10, 2008 | 07:32 PM
Mike Rainbird
Caraholic
I'm on T6 though, which can even monitor turbine wheel speed amongst it's many abilities, but I still wouldn't run the EGT control other than to turn the ALS off .
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
