taking an alarm from one car to another
Old Jul 9, 2008 | 07:42 PM
BM08's Avatar
BM08
Default taking an alarm from one car to another
whats the crack on this? too much hassle/ not possible, or can it be done by a pro?
Old Jul 9, 2008 | 07:47 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Possible, but would not recommend it especially if there's immobilisation involved. The quality of the installation is more important than the alarm itself (IMO) and you'll have a job doing it without good 'electrical skillz'. In my experience a pro would charge a fair bit to 'unwire it' too.
What alarm is it?
Old Jul 9, 2008 | 07:48 PM
ff123's Avatar
ff123
yep can be done but make sure you label it well
never buy one thats been took off unless labelled
Old Jul 10, 2008 | 06:50 AM
Piece of piss, took a C5T2 from a escort diesel to a astra, there is NO reason it will not work if wired correctly as it does not know what car it is on, immobilisation is childs play to get around as well when doing the whole job like this.
Old Jul 10, 2008 | 10:00 AM
BM08's Avatar
BM08
where abouts are you based? and how much would you charge?
Old Jul 10, 2008 | 07:17 PM
It's easy to do yourself, just lable as you remove, write eveything down and take your time.
Immobiliser circuit normally a loop that is cut and then joined into starter/dash/fuel pump/ecu feed after the wire to that is cut.
I am in Norfolkshire.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
