crap quality focus rs spark plugs.....
ive had 2 sets of genuine ford focus rs spark plugs. The 1st set 2 of them cracked (the porcelene) so i bought a new set (one cracked) so changed that, then car had a miss fire, all plugs sparked, but turned out 2 were shite, after help from gup turned out it was brand new spark plugs which just wernt good enough, bought new ones again and is spot on, just think they are shite qualit now and ain impresses
alternator giving a little grief as not charging so caused me a bit of a splutter then died (had lights, fans etc on and didnt have the charge) left it ticking over for a while with them off and gave it Ł50 in the tank to ensure its getting fuel and feels better
, need to get it to someone thought to check the map etc over but dont know who? lol
thiers a guy called winston that ive taken a few cars to and he can set your c.o up for you fella so that will make it run better
hes well clued up and hes not that far from you either
mates going to wire up the lamba and thw wideband, so it will just need enabling on the ecu which i think then gives it self adaptive mapping? (within reason)
I have never heard of any or had any myself problems with the standard Ford plugs!
I know of 3 destroyed engines due to Denso ITV 22's failing and a mate who removed a plug that he could flick the electrode off a ITV22!
sounds like they beed dropped if its the porcelin,,, considering the engines never ran its not a faulty plug
dont buy any plugs from there again as it sounds like a place that picks em up and puts them back on the shelf
once dropped theres a good chance there cracked if its on the floor so time for the bin
, engine has run, the final 2 fooked plugs look physically fine, had a spark, just werent good enough
As already suggested sounds as though the ones you've got have probably been damaged at some point - there are a number of high power FRS running the standard Ford plugs without any problems at all - i certainly wouldnt say the quality of the product itself is crap tbh
i'm considering ditching my zetec plugs all together and machining the seat to take cossie plugs... problem solved! i haven't found a descent zetec plug with a good heat range for a turbo car yet
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
DixieTheKid
Sep 14, 2015 09:04 PM
