mod to rev clock when on coilpack ?
Old Jul 7, 2008 | 12:01 PM
scoooby slayer's Avatar
scoooby slayer
Default mod to rev clock when on coilpack ?
can anyone please tell me what the mod is thats done to a saph rev clock to work on coilpack.
Old Jul 7, 2008 | 12:08 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its detailed in the instructions when you buy the coilpack isnt it?
Im sure I have a copy somewhere, failing that im sure stu has a PDF
At least you CAN do it on a saph, no definitive fix still on a 3 door one that im aware of
Im going to try the diodes route on mine.
Old Jul 7, 2008 | 12:11 PM
xr4x4rs's Avatar
xr4x4rs
whats your email mate, ill forward the on i got off stu
Old Jul 7, 2008 | 12:13 PM
scoooby slayer
apparantly the mod has been done and it did work fine but its started playing up now giving false readings it never goes above 5k now and seems to read about 50 % of true rpm. im wondering what i can check or if i need to get a new rev clock and have the mod done whatever it is.
Old Jul 7, 2008 | 12:14 PM
scoooby slayer
hi thatd be great my email is billycossie@fsmail.net
thanks
Old Jul 7, 2008 | 12:20 PM
xr4x4rs's Avatar
xr4x4rs
email sent
Old Jul 7, 2008 | 01:55 PM
Bart's Avatar
Bart
Could you also mail it to me? My e-mail adress is Bartvandeun@hotmail.com
Thanks!
Old Jul 7, 2008 | 02:00 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Another thing to check - make sure you are still getting full battery voltage up in the high rev range - remember, on boost, the fuel pump will draw much more current and the voltage the ECU/IAW sees will drop significantly if the wiring is old and past its best. The IAW needs above 12 volts to make the rev counter work efficiently, any less and the rev counter will fail to work.
How do I know this - I found out accidentally when a coolant hose split, thus soaking the alternator, reducing the output to 9 volts and the rev counter stopped working utill the alty was producing the correct voltage once again.
Old Jul 7, 2008 | 03:12 PM
3 door tachos work with a TACHO driver(Ł30), and what I am using on my sapphy tacho.
Chip's Avatar
Chip
Is that the ones dave walker sells?
Old Jul 7, 2008 | 03:14 PM
Garage19's Avatar
Garage19
Ł30?
I hope he is not selling the diode mod packaged up for Ł30.
Should cost 58p for the diodes from maplins.
Old Jul 7, 2008 | 03:17 PM
scoooby slayer
battery voltage is 14v flat out on secs so thats all good.
Old Jul 7, 2008 | 03:22 PM
scoooby slayer
email sent
thanks mate is that just a piece of wire joining the 2 connections ? im gonna get a new rev clock i think so just wana check what it is i gotta solder into it.
Old Jul 7, 2008 | 03:25 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
just buy a decent accurate rev counter the standard one is not accurate and only shows 7k
Old Jul 7, 2008 | 03:27 PM
Chip's Avatar
Chip
Originally Posted by Garage19
Ł30?
3 diodes, the case, some instructions, the time to write it all, 30 quid sounds perfectly typical to me, cant see why you would hope one way or the other, not like he could afford to do it for a fiver after all!
Old Jul 7, 2008 | 03:54 PM
costina's Avatar
costina
Live long and prosper!!
Done my saff one as per Stu's instructions works fine
And the secs reads the same too(SOMETIMES)
Paul
boeb
Jan 9, 2020 05:11 AM
Mark_
14
Jan 16, 2016 05:27 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Mr S1
20
Sep 27, 2015 04:06 PM
