Fuelling problem help techies!!!
Old Jul 6, 2008 | 06:22 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default Fuelling problem help techies!!!
Right its a scoobie but not asking there as never can get any tech answers there....
My95 classic scoobie (missis car) has been sat a week as she been away with work.
Come to start up and its lumpy etc. Wideband is either lean as fuck (18.1) or its all over the scale lean rich lean rich like mad. LC1 is controlling what ecu is seeing (inplace of standard lambda) and shows no fault on calibration, engine temp sensor is new, does it on lambda control and wot but no engine check light.
Any ideas???? ive put frsh fuel in too
Any idea where diagnostic plug is on scoobs?? i can then connect up lappy and see what sensors are showing ecu
Old Jul 6, 2008 | 06:46 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
diag sockets under drivers side. have you tried disconnecting the wideband?
Old Jul 6, 2008 | 07:41 PM
dannyblackpool
Boost Builder
disconnecting wdeband would put it into limp so no i havnt, might put std lambda back in and fit boss and run both see if helps
Old Jul 6, 2008 | 08:05 PM
NEEDFORSPEED
i shouldnt think it would go into limp disconnecting lambda would just stay open loop and put light on. id say id plug our jap machine in and have a look but it was nicked out of my van on friday! have you checked the output to ecu with a multimeter yet to see if its switching properly?
Old Jul 6, 2008 | 08:06 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I'd re-calibrate the LC1 - i've seen this happen before with them, they can lose their calibration.
Old Jul 6, 2008 | 08:12 PM
dannyblackpool
Boost Builder
not done a free air calibration, not checked outputs either, will disconnect lambda in morn and then will try to find diag plug again and see what laptop comes up with
Old Jul 6, 2008 | 08:13 PM
NEEDFORSPEED
no worries if you get stuck give me a pm im only down the road bud
Old Jul 6, 2008 | 08:15 PM
dannyblackpool
Boost Builder
cheers m8 need to sort as getting it in the neck already from "the boss" lol
Old Jul 6, 2008 | 08:27 PM
NEEDFORSPEED
lol no worries. will be something and nothing very rarely have major problems with them
Old Jul 6, 2008 | 10:38 PM
stevieturbo's Avatar
stevieturbo
C**t
LC-1's can be very problematic.
Either throw a narrowband back in, or leave it unplugged and try it.
Although a description better than lumpy might help. Is it off cylinders ? At idle, or all the time ?
Will it drive ?
Have you checked the coils and plugs ? These can often be damaged when people are fitting plugs. Over time the coils can go brittle, and it doesnt take much to break them. People also lose the rubber insulating boots somehow, or damage them.
You wont be connecting a laptop up easily....unless you develop some software to do it lol.
But there are connectors under the dash that will flash any fault codes. Very easy to do, although if the CEL isnt on, then chances are things are ok.
Old Jul 7, 2008 | 08:09 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Will it drive ?
how can you tell, it's a subaru
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
