cossie engine HELP!
Old Jul 5, 2008 | 07:44 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default cossie engine HELP!
well its a long winded story but i could really do with a bit of advice this time
ok, rebuilt my engine, new forged pistons, rebore, block deck skim, new head, all bearings replaced,
ran it up for the first time yesterday and had a faint tapping sound, asumed it was tappets, so ran it for 20mins it wouldnt go away,
did some testing this morning, and the tapping stopped when no3 injector was unplugged.
i bit the bullet and removed the head,
why would this stop when i unplugged the injector? the only thing i can think off, is the kick of the ignition making the piston kick over was enough to make it contact?
now, i did dummy build this and it didnt show up then. so must only happen at speeds above me turning it over by hand
number 3 piston now has a clonk when i rock it from side to side, the others have the same movement but no noise....could this have damaged the skirt?
number 3 cylinder was also runing rich by the look of it, as all the valves were clean, and exhaust port wes sticky, i have been aware on my last engine of no3 running richer than the others, so maybe i have an ecu issue aswell? and maybe it was borewashing no3 hence the noise when i rock the piston?
so what do it do now? what do you reckon?
obviously im now going to remove the pistons, get them measured up, and skimed if ok, but they only ran for 20mins
Old Jul 5, 2008 | 07:49 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
ehh piston have tuched the head???
how about the valves, are they ok?
Sounds like you might have a small end bearing failure or even big end
Old Jul 5, 2008 | 07:51 PM
trevCOSS's Avatar
trevCOSS
oh bugger gudgion pin?
JTECH James
Passion for Fords!
it has massive valve cut outs, so the valves have not touched,
big ends are new, and it didnt sound like a big end at all,
small ends were a real nice fit,with new pins i cant see it being that, but i will find out tomorow
Old Jul 5, 2008 | 07:53 PM
JTECH James
Passion for Fords!
the pistons do protrude the block now after its deck skim, martin told me to be aware of contact, so i did a dummy build...but its touching when it runs
Old Jul 5, 2008 | 07:54 PM
trevCOSS's Avatar
trevCOSS
badly machined piston perhaps?
Old Jul 5, 2008 | 07:55 PM
trevCOSS's Avatar
trevCOSS
sounds like you have your answer
Old Jul 5, 2008 | 07:56 PM
JTECH James
Passion for Fords!
its weird isnt it, as none of the others touch, or are noisey when rocked side to side,
they all have the same movemnt in them, but only no 3 clonks as the skirt taps the bore
JTECH James
Passion for Fords!
why only no3 tough trev?
Old Jul 5, 2008 | 07:59 PM
trevCOSS's Avatar
trevCOSS
yes it is strange, if its only 3 it either has to be the physical measurements of the piston are different to the others or you have big or little end problems, or your crank has been very badly ground.
Old Jul 5, 2008 | 08:00 PM
JTECH James
Passion for Fords!
crank is standard...
Mark Shead's Avatar
Mark Shead
The pistons should only rise above the block 15thou, the rest will only be a guess until you strip it.
Mark
Old Jul 5, 2008 | 08:01 PM
Munch's Avatar
Munch
Mr. Sparkle!
shit man, this aint sounding good
Old Jul 5, 2008 | 08:02 PM
glancy2081's Avatar
glancy2081
were these the rods used in your last engine
JTECH James
Passion for Fords!
makes me wonder if its this overfuelling issue washing the oil off the bore...
i know the tapping was the head contact...but what about the slapping?
Old Jul 5, 2008 | 08:04 PM
LHD220Turbo's Avatar
LHD220Turbo
very strange? maybe one for the pro engine builders to answer? cant get my head round that at all James
JTECH James
Passion for Fords!
yeah...same ones
Old Jul 5, 2008 | 08:05 PM
JTECH James
Passion for Fords!
Mark
thats true, il see tomorrow....
Old Jul 5, 2008 | 08:06 PM
glancy2081's Avatar
glancy2081
did you measure the rods lengthbefore the build as for the slapping if it goes away when injector is un plugged surely it has to be a injector or ecu fault
Old Jul 5, 2008 | 08:07 PM
Dan's Avatar
Dan
Wounder James, hope it gets sorted mate
Old Jul 5, 2008 | 08:09 PM
trevCOSS's Avatar
trevCOSS
in one way its odd that it goes away as it must mean that you cant hear the piston to head contact? as when you remove the injector the piston should still be hitting the head? mabe your just hearing slap
Old Jul 5, 2008 | 08:12 PM
JTECH James
Passion for Fords!
i can only think when it fires, the piston kicks, which is normal, but cos the heads so close it kicks and the high side taps the head???
Old Jul 5, 2008 | 08:14 PM
cossiemanden
maybe the block have been skimmed to much?
Old Jul 5, 2008 | 08:15 PM
cossiedave's Avatar
cossiedave
had this when i done a engine on my old saph and it turned out that the pistons were all different hights so had them miled off 10 tho and it was fine and is still going now have alook how high they are out the block like mark said should not be out the block no more than 15 tho
Old Jul 5, 2008 | 08:16 PM
JTECH James
Passion for Fords!
4 thou....however, i can just deck the pistons to match...
Old Jul 5, 2008 | 08:18 PM
trevCOSS's Avatar
trevCOSS
0.004" difference between pistons I assume?
Old Jul 5, 2008 | 08:20 PM
JTECH James
Passion for Fords!
block was skimmed 4 thou
turning it over by hand i felt no contact at all, its only when running.
Old Jul 5, 2008 | 08:21 PM
cossiedave's Avatar
cossiedave
is this what it is now m8
Old Jul 5, 2008 | 08:22 PM
CharlieSaff's Avatar
CharlieSaff
I don't mean to seem rude, but I was once told by one of the best in the game; when referring to what people had advised me on here; and they said "Yes, and how many of them are professional engine builders?" I then ended up taking his advise, on what a lot of people on here said was a bad idea, 3+ years later, and my engine is still PERFECT
Ring a professional Monday
Old Jul 5, 2008 | 08:24 PM
glancy2081's Avatar
glancy2081
get a clock gauge and check how much each piston protudes the block
Old Jul 5, 2008 | 08:26 PM
JTECH James
Passion for Fords!
the block was skimmed 4thou, but i didnt skim the pistons, as it felt fine on the dummy build...
Old Jul 5, 2008 | 08:28 PM
JTECH James
Passion for Fords!
i am more than quaified thanks
this is my toy, that i have built, i will overcome any issues i have, and people on here help me on my way, as its not quite normal anymore, and many have experience with engines of a similar spec to mine.
no fun in paying someone to build it at all imo
Old Jul 5, 2008 | 08:38 PM
Mark Shead's Avatar
Mark Shead
Was the pistons bored for each pot and fitted that way, did you check bearing clearances and crank size.
Mark
Old Jul 5, 2008 | 08:43 PM
JTECH James
Passion for Fords!
well, the block was bored by martin at reyland, and they waited for pistons before the bore, so i assume they were measured up mark, however they wernt numbered, so must have been close enough to each other id guess?
the crank was checked and polished but still perfect in std size, and was perfect in my old engine, as were the rods etc
Old Jul 5, 2008 | 09:36 PM
JTECH James
Passion for Fords!
can you re uise the wrc gasket? or is it going to cost me another Ł170
Old Dec 9, 2008 | 09:52 PM
dom123's Avatar
dom123
did this ever get sorted?
Old Dec 9, 2008 | 09:57 PM
Paul_RS's Avatar
Paul_RS
I assume so, but the head was damaged and the engine is apart again at the moment.
Old Dec 9, 2008 | 10:06 PM
JTECH James
Passion for Fords!
yeah, twas a rogue piston,
now i had valve seat failure..
god im lucky!
back soon!
Old Dec 9, 2008 | 10:07 PM
Paul_RS's Avatar
Paul_RS
back soon!
Bigger and better than ever
Old Dec 9, 2008 | 10:08 PM
JTECH James
Passion for Fords!
thats the plan mate ,lol
