can an injector click but not work?
Old Jul 5, 2008 | 05:10 PM
rst in breaking's Avatar
rst in breaking
Default can an injector click but not work?
ive got a problem i believe to be 2 injectors, they click, have been cleaned and eveything upto the injector is working including spark and compression, any help much appreciated, thank you
Old Jul 5, 2008 | 07:18 PM
frankyboy's Avatar
frankyboy
Well i had a similiar prob on my saff cos last week it stated to miss bad, i had a spark on all 4 plugs, changed crank sensor still missed! I thought it was injector probs cause if i pulled of the connector on injectors 1&3 it made no difference to engine note, they were clicking thou so were working. A few days later i found it was the dizzy cap and rotar arm somehow putting a spark on plugs 1&3 at same time! Maybe it's all your prob is, hope it helps.
Old Jul 5, 2008 | 08:23 PM
gup's Avatar
gup
try swapping them to another cylinder and c if the prob follows it fella
Old Jul 5, 2008 | 11:43 PM
rst in breaking
im running on efi though mate, have pulse up until the injector then i believe im getting nothing onwards
Old Jul 5, 2008 | 11:44 PM
rst in breaking
was going to try this 2moro, just a pain as it involves taking the plenium apart again , cheers
Old Jul 6, 2008 | 03:19 PM
rst in breaking
i switched the injectors about today and problem remains so am really baffed now, anyone have any ideas? thank you
Old Jul 6, 2008 | 03:20 PM
RickyLee53's Avatar
RickyLee53
Cam etc ok?
Old Jul 6, 2008 | 03:25 PM
rst in breaking
in what way? exhaust cam is brand new are six cam, inlet is standard 2.0
Old Jul 6, 2008 | 03:55 PM
gup's Avatar
gup
did the prob follow when you changed the injecters around
Old Jul 6, 2008 | 04:00 PM
rst in breaking
the problem remained on cylinders 2/3 still which really really puzzled me?
Old Jul 6, 2008 | 04:42 PM
Ginge !'s Avatar
Ginge !
just finding my feet
aint the injectors then
Old Jul 6, 2008 | 05:36 PM
rst in breaking
nope, just stressing me out as i dont know what it is? may have to take it incase its something in the map? im out of ideas now
Old Jul 6, 2008 | 05:40 PM
XRT_si's Avatar
XRT_si
Checked the loom/injectors and its gettign a spark. Something awfully wrong there Paul
You've had so much bad luck with that car
Old Jul 6, 2008 | 05:45 PM
rst in breaking
wont be something major i dont think as all the basis for it are there
Old Jul 6, 2008 | 05:54 PM
Ginge !'s Avatar
Ginge !
paul if its gettting spark and the injectors are working then it should run
if it aint then theres a issue,,, could be anything too even a air leak will make the car missfire or the cam timing being out ect ect ect
Old Jul 6, 2008 | 06:02 PM
rst in breaking
i know, thats what i was thinking, but with compression on all cylinders fueling and sparking im puzzled, maybe the plug gaps could be wrong? i really dont know now? may take it to jano in the week
Old Jul 6, 2008 | 08:40 PM
gup's Avatar
gup
swap the plugs around fella i might be able to have a peek for you in the week as i work in chingford fella if you want
2 heads are better than one lol
are the readings all even when you checked compression
cant be injecters if the prob remains when you swapped them over
could have the wroung signal from the ecu going to that cylinder
no way you could of mixed them up by any chance is thier dude
Old Jul 6, 2008 | 08:59 PM
focusv8's Avatar
focusv8
Fuel rail blocked over 2 and 3?
Try looking in at the engine in the dark to see if you have sparks flashing from 2 and 3 to each other or earth.
Air leak on the inlet around 2 and 3 ?
Old Jul 6, 2008 | 09:21 PM
rst in breaking
air leak on the inlet is very poss, i did mention this to a few people as i re-used the inlet to head gasket just to get it started and it had a lil nip in it (was replacing after but wanted to check engine run, due to getting bent valve before with disaster) but werent working at the time so couldnt afford to replace but wanted to know it ran. how likely could it be?
Old Jul 6, 2008 | 09:22 PM
rst in breaking
where abouts do you work in chingford mate? cheers btw
Old Jul 6, 2008 | 09:35 PM
gup's Avatar
gup
in peugeots fella
Old Jul 6, 2008 | 09:41 PM
rst in breaking
in peugeots fella
south woodford?
Old Jul 6, 2008 | 09:44 PM
gup's Avatar
gup
oh in your avatar is it says your in chingford
Old Jul 6, 2008 | 09:47 PM
rst in breaking
i am in chingford, i just cant think of a peugeot dealer in chingford lol, saying that the one in woodford is now flats lol, where abouts is it?
Old Jul 6, 2008 | 09:48 PM
gup's Avatar
gup
lea valley road
by the shell garage
auto planet
poss 2 mins from ollie is it and si
Old Jul 6, 2008 | 09:51 PM
rst in breaking
yeh, i know both well lol, du work with big dave?
Old Jul 6, 2008 | 09:55 PM
gup's Avatar
gup
yea man know big dave well
ask him about gup if you want some back ground about me lol
we was talking about your car when you first started the restro
poss might know tom hasler to
Old Jul 6, 2008 | 09:58 PM
rst in breaking
may know him if i see him, see dave drive past a fair bit with me covered in crap working on the damn thing lol, its so close which is now bloody annoying lol
Old Jul 6, 2008 | 10:00 PM
rst in breaking
its freaky how many people know my car without me hardly ever driving it lol, about the 1st time i took it to enfield pf meet 3 people spoke to me, knew the car etc, its concerning
Old Jul 6, 2008 | 10:02 PM
gup's Avatar
gup
always the way fella
Old Jul 6, 2008 | 10:03 PM
gup's Avatar
gup
i know dude alot of daves mates now me from my van
rst in breaking
yeh i know, took me fiesta turbo there once, next day it was gone
Old Jul 6, 2008 | 10:05 PM
rst in breaking
what van was it? black rs one?
Old Jul 6, 2008 | 10:07 PM
gup's Avatar
gup
cant have nothing now days
where did you take the fiesta dude
never spoke to si or ollie tho
i normally drive past poss ollies house as a short cut on the way home
normally loads of people outside his house sometimes
Old Jul 6, 2008 | 10:08 PM
gup's Avatar
gup
nah man its a mk6 van thats been decked and has a big jet fighter exausht on it
Old Jul 6, 2008 | 10:09 PM
rst in breaking
nope, not seen that around lol, what engine does it run?
Old Jul 6, 2008 | 10:11 PM
gup's Avatar
gup
the almighty 1.8d with a drilled airbox
looks smart tho for a van gotta admit
Old Jul 6, 2008 | 10:12 PM
rst in breaking
not long got rid of my mk6 was nice little van, all the electrica etc ghia dash, colour coded bumpers, sold it and got its big brother, the transit lol
Old Jul 7, 2008 | 08:54 AM
Jim Galbally's Avatar
Jim Galbally
what about the tappets? you SURE the valves are opening/closing correctly
Old Jul 7, 2008 | 12:53 PM
rst in breaking
i was just about to ask that as somebody mentioned it lol, its a little bit tappety so was thinking maybe the tappets need removing and compressing as they were left sitting for a while?
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
dojj
Aug 12, 2015 08:52 PM
