boost question
Old Jul 5, 2008 | 03:34 PM
benidormsteve's Avatar
benidormsteve
Default boost question
how do you turn the boost down on a sierra saff cos and how do you know when its at a safe level without doing damage to the turbo or engine(no boost gauges in the car)
cheers
Old Jul 5, 2008 | 04:07 PM
mechanic28's Avatar
mechanic28
why do u want to turnn the boost down?what spec?whos chip etc?generally i would say let a tuner do it!or at least get in contact with whoevers wrote the chip
Old Jul 5, 2008 | 04:16 PM
benidormsteve
i havent got the car yet and im asking just in case i buy a cosworth and the boost is too high and ends up damaging the car.
when living in spain.there aint alot of rs mechanics around in spain to sort the problems.
Old Jul 5, 2008 | 04:22 PM
mechanic28's Avatar
mechanic28
i see well in truth is best not to touch anything without asking who wrote the chip!but if needed u just lengthen the actuator rod,by roughly a turn should be enough
Old Jul 5, 2008 | 07:58 PM
LHD220Turbo's Avatar
LHD220Turbo
thought you were buying a t5 volvo?
as above; just make the actuator rod longer; but if the car is chipped/ set up it might cause issue with fuelling etc
you'll need a few turns of the rod to feel any effect; i think i read somewhere that 1 turn equates to 1 psi (not sure how true that is tho)
Old Jul 5, 2008 | 07:59 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The ONLY way to know its safe IMHO is a set of det cans and an AFR gauge.
Perfectly possible to melt a cossie engine at half a bar of boost if its not setup right!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
