A basic setup
Old Jul 5, 2008 | 09:12 AM
juffer's Avatar
juffer
Default A basic setup
hi all,
Im have just put a rs turbo engine in my cabriolet. I want to set the timing correct as much as i can before i go to a tuner miles away. The car is running at 1 bar of boost and the timing is currently set at 16 degrees advance is this too much advance? What is your timing figures? As what i have read up on the more boost you put in the less advance you need is this correct? The engine is standard with the usuall exhaust,filter,-31 actuator and castle performance chip.
thankyou
Old Jul 5, 2008 | 09:16 AM
Stu @ M Developments's Avatar
PassionFords Creator
Only Castle can answer you as it depends on the chip.
Old Jul 5, 2008 | 09:35 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I think 12 degrees would be a safer starting point though, but you should get it checked by a tuner.
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
