how easy to change front wheel bearin?
Old Jul 3, 2008 | 08:55 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default how easy to change front wheel bearin?
series 2 front wheel bearin is fucked how easy is it to change? how long?
Old Jul 3, 2008 | 09:31 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
theres a post about this not long back,its a pretty easy job,depends how fucked it is!i just change the whole hub,easier still
Old Jul 3, 2008 | 09:33 PM
sortedsaff's Avatar
sortedsaff
easy peasy fella anything your stuck with just ask
Old Jul 3, 2008 | 09:40 PM
g1234's Avatar
g1234
easy as long as you got a big hammer lol
Old Jul 3, 2008 | 09:50 PM
tobyjug_1988's Avatar
tobyjug_1988
pretty simple, just watch the bottom bolt and nut that holds the ball joint to the bottom of the stub axle, i did mine and snapped the fucker, was a right cunt finding a bolt that fitted.
Old Jul 4, 2008 | 10:14 AM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
my advice is take the whole hub off which is really easy and take it to your local garage, aske them to press it out. I wouldnt recommend using a hammer n socket etc, they are really easy to damage. It cost me 20 for thr bearing and a few tinnies at my local garage, but he is a mate of mine
Old Jul 4, 2008 | 05:54 PM
fonfe's Avatar
fonfe
get it pressed out, always use the right tools when you can, or its just a temptation for things to go wrong, and eventually they will.
Old Jul 4, 2008 | 08:50 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i have found out that i need new hubs and carriers as they have water corrosion
JoeyBoyden
Jan 4, 2024 02:36 PM
Chas
Sep 21, 2015 08:57 PM
st220kyle
16
Aug 14, 2015 06:13 AM
track.focus'd
Aug 12, 2015 05:53 PM
muz
Aug 1, 2015 06:48 AM
