14 psi what bhp?
Old Jul 3, 2008 | 04:59 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default 14 psi what bhp?
my series 2 shows about 14psi on the gauge, what bhp is this?
Old Jul 3, 2008 | 05:04 PM
HoylaRS's Avatar
HoylaRS
Piss taker
depends on whats been done! is it standard?
Old Jul 3, 2008 | 05:10 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
it has a switch, when switch is towards me its a standard rs. but flick the switch goes to 14psi. it has frount mounted intercooler, paddle clutch, group a coil.
Old Jul 3, 2008 | 05:12 PM
HoylaRS's Avatar
HoylaRS
Piss taker
would guess and it is a guess at about 140/50 bhp! could be wrong! see what other people think!
Old Jul 3, 2008 | 05:26 PM
LHD220Turbo's Avatar
LHD220Turbo
dont think you can guess the bhp without the spec, what turbo would be a good start!?
Old Jul 3, 2008 | 05:27 PM
HoylaRS's Avatar
HoylaRS
Piss taker
did ask him what had been done! i guessed and thats all you can do really!
Old Jul 3, 2008 | 05:36 PM
Noisy Boy's Avatar
Noisy Boy
2000bhp
Old Jul 3, 2008 | 05:39 PM
HoylaRS's Avatar
HoylaRS
Piss taker
Originally Posted by Noisy Boy
2000bhp
you dont have a clue mate............................2005bhp
Old Jul 3, 2008 | 05:48 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
237.4bhp @ 5840rpm
Old Jul 3, 2008 | 05:52 PM
Noisy Boy's Avatar
Noisy Boy
dam i was way out!
Old Jul 3, 2008 | 07:35 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
its the std turbo i believe i know its a t3 but not sure what stage?
Old Jul 3, 2008 | 10:34 PM
stuart collins's Avatar
stuart collins
mine was 259 @14psi
Old Jul 3, 2008 | 10:47 PM
Chris69's Avatar
Chris69
more details needed dude
is it still mfi or efi- wot turbo and who has set it up? if its on mfi still i'm sure its not easy to have high and low boost setup accurately
Old Jul 4, 2008 | 10:17 AM
Smartdj.'s Avatar
Smartdj.
mine was 170@flywheel @10psi befor the bottend went (standard engine)
Old Jul 4, 2008 | 12:17 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
you were way out man
2006.1bhp
Old Jul 4, 2008 | 08:52 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
it has mfi gear still engine needs settin up on rollers. so ill know then. different note easy to change valvestem seals?
Old Jul 4, 2008 | 09:00 PM
Pat's Avatar
Pat
Mine was about 260bhp at 15psi..
Now its running 24psi..
Old Jul 4, 2008 | 09:03 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
160-180 on a good engine/turbo
Old Jul 5, 2008 | 12:58 AM
Smartdj.'s Avatar
Smartdj.
is it hard 2 go efi on s2
Old Jul 6, 2008 | 11:30 PM
T28 RST's Avatar
T28 RST
Ok then
Could be 120 bhp or 150 bhp or 200 bhp or 400 bhp, no one could puta figure on the info you have given
Old Jul 7, 2008 | 04:24 PM
mart rs's Avatar
mart rs
will be 175 ish m8
Old Jul 7, 2008 | 04:41 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
usually between 170 bhp and 195 bhp if its got just got a chip which i guess it has if it doesnt over boost at 14 psi. mine had bigger intercooler chip and kent cam and that made 210 bhp at jamsport
Old Jul 7, 2008 | 04:45 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
96bhp for sure mate
Old Jul 7, 2008 | 05:04 PM
Dan16v's Avatar
Dan16v
3bhp
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Marv888
Sep 26, 2015 03:44 PM
