Pic request... arch repairs
After pics of you repairs to your rear wheel arches before paint and filler... and whats the proper way to weld in the repair pannel so rust dont come back, and the repair doesn't start to crack...
I need both rear arches on my MK2 Orion sorting before paint...
best way to do it is to cut out the shit metal and weld in a repair panel, fill & prep it before paint.
If you fill the rust hole it wont last a month or 2 before it starts to bubble...trust me!
Dan
Dan
heres a few (of many) pics of my frst ear arches been done by me mate. Hes a electrician.... but just happens to be very good with cars all round! (body & engine)
Anyway, work done in garage / on drive... took a week from taking plastic arches off to completion!
If u need more pics like the inner arches that he fit to ETC then email me.
This was the very next day!
Thats it, like i sed tho, many more.... close ups ETC!
CheeRS
Gib
CheeRS
Gib
Cheers for the posts...
G18rst, looks a mint job that, my arches are no way near that bad, but I want them right before it goes for full paint...
Has the replacement arch been slide between the inner and outer pannel? And is it welded from both sides?
MarkC... will let you know, cheers
Thanks again all, anymore?
Theres some very able peeps on here
Both the above look top knotch jobs...
Has the repair pannel been slid in between the inner and outer? Has it been welded on both sides?
Both the above look top knotch jobs...Has the repair pannel been slid in between the inner and outer? Has it been welded on both sides?
best tip i can give you is dont cut off too much off the repair panel in one go do small amounts and do your weldin a bit at a time to if you get the pannel hot is will warp and lose shape
inner and outer panels completly welded. best advice i could give make sure they fit before welding (that is critical) and but weld them making sure there is a gap between the two panels the width of a hacksaw blade.
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 24, 2015 11:11 AM
