air compressor
Old Jun 28, 2008 | 11:19 AM
slimwynn's Avatar
slimwynn
Default air compressor
hi all i'm after a new compressor but i'm not sure what size to get,it will be used for sander and spraying any iders cheers
Old Jun 28, 2008 | 01:24 PM
If used with a DA sander, a F*****G big one, they gobble up air like theres no tomorrow, spraying is not so bad as you can use HVLP stuff, and only done a bit at a time, just look at FREE air delivery rating of sander etc, often just getting a bigger tank will pay to do as you have more reserve.
Old Jun 28, 2008 | 02:08 PM
slimwynn's Avatar
slimwynn
i'v got the da sander box in front of me but all it sez on it is 4cfm@90ps1,1000 rpm i can't find anything about free air.
Old Jun 28, 2008 | 02:57 PM
slimwynn's Avatar
slimwynn
this one any good ??? https://www.machinemart.co.uk/shop/p...air-compressor
Cossiep's Avatar
Cossiep
Can't remember the exact calculation but those figures sound like they would be at 25% duty cycle i.e. only running for 15 seconds then stopped for a minute, so to get a real figure it'll consume more like 16cfm if used continuously so to power it without compromise you'd be looking at a large 3 phase jobbie supplying 25cfm at least.
Old Jun 28, 2008 | 03:00 PM
Cossiep's Avatar
Cossiep
Would probably do the job it used immtermitantely (sp) but having done extensive research when buying my last compressor, if you want workshp type performance you need three phase as even the biggest twin motor 240v compressors are just about up to ''proper'' workshop useage.
Old Jun 28, 2008 | 03:40 PM
slimwynn's Avatar
slimwynn
how long would i have to use the sander b4 i have to wait 4 the compressor to build up again?? if i was using the compressor that is on the link
Old Jun 28, 2008 | 04:44 PM
The one in the link will cope easily with the sander you have, it's bigger than you need, but bigger is better with DA's.
Old Jun 28, 2008 | 04:52 PM
dojj's Avatar
dojj
Resident Wrestling Legend
thats the same compressor i've got
it's great for doing everythng i need to do with it, impact drives and stuff as well as drilling and cutting, even the air saw works fine from it and it builds up quickly once its up to pressure
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
