White Sludge
Old Feb 5, 2004 | 10:16 PM
Default White Sludge
Hi all I have a prob i hope someone can advise me on. I havs an xr3i cab which runs fine, always starts idles fine. The car doesnt get driven that much but whenever I take out the dip stick its covered in white sludge. Now 1st thing that springs to mind is head gasket???? However I am not losing oil, not losing water no sludge in top half of engine and after a few cleans of the dipstick it is all clear. Would this be that there maybe a little sludge in the bottom of the engine or m I looking at something more serious.
Any advice much appreciated
Simon
Old Feb 5, 2004 | 10:27 PM
Uncle Henry's Avatar
Uncle Henry
probably just condensation due to not being used very much.
give it a change and keep an eye on it. If it dont get worse dont worry about it
Old Feb 6, 2004 | 07:40 AM
give ur engine a flush matey. pop into a store and pick up a can of engine flush and then take the sump off and clean it ouit so u r sure it is clean. IOf the sludge blocks the oil pump pickup tube then say goodbye to those bearings!
James
Old Feb 9, 2004 | 08:18 PM
take on a good run and check again
Old Feb 10, 2004 | 05:06 PM
Had a Pug GTI with a similar problem. Turned out to be a split breather pipe letting moisture in and contaminating the oil. Changed the pipe flushed the engine and it never happened again. Worth a good check round all the pipes and while they are off give them a good clean out, to help with the breathing.
Matt
bobsworth
77
Mar 24, 2016 09:30 PM
mk1turboestate
Dec 2, 2015 08:31 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
SMILER258
Sep 28, 2015 09:04 AM
