my fuel pump prime sounds weak/non runnin rs
Old Jun 27, 2008 | 08:10 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default my fuel pump prime sounds weak/non runnin rs
cant get my car 2 start, bin off the road 10 months, no fuel getting to the injectors but everywere else, my pump doesnt prime nice an loud like it use 2, so i bought another 2cd hand one, an it sounds exactly the same weak, do u think i hav a faulty wire causing this? cheers
Old Jun 27, 2008 | 08:14 PM
micxr3i's Avatar
micxr3i
i think you ve been sold a dodgy second hand one tbh!!
mic.
Old Jun 27, 2008 | 08:16 PM
turbolee1977's Avatar
turbolee1977
hi m8 your injectors might be blocked if its bin off the road that long. take one injector off put it in a clear plastic bottle turn ignition on then push metering unit flap down petrol should fire threw injector if not its blocked. also check your fuel return pipe to ya tank it mite be blocked.
Old Jun 27, 2008 | 08:28 PM
TuRbO-CaB-LaD
i havnt took the injectors out yet, iv had the 4 injector pipes off at metering unit an pressed flap whilst its bein cranked but it trickles out, an doesnt hav enuff pressure to go up the line to the injector, might i have a airlock ? if so how do i check/fix cheers
Old Jun 27, 2008 | 08:29 PM
PaulT's Avatar
PaulT
at the back of the pump there is a non return valve valve that sticks, this happened to me, i changed many pumps but not the valve so may be worth a try.
Cheers PaulT
Old Jun 27, 2008 | 08:45 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
HAve u tried to change the fuel pump relay?
Old Jun 27, 2008 | 08:50 PM
TuRbO-CaB-LaD
Cheers PaulT
cheers wil check tomorrow morning
nope i havnt changed it as i fort it was working ok cause the pump is priming, would it still prime with a faulty fuel pump relay?
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
15
Oct 7, 2015 03:43 PM
kevin36
Sep 8, 2015 12:23 PM
