Another Stupid Question
Old Jun 27, 2008 | 06:08 PM
SWIFTY's Avatar
SWIFTY
Red face Another Stupid Question
Is There A Way To Tell Witch Cam Is In An Which Is Ex Or Are They The Same?? As Looking At Them I Carn't Tell Any Difference Between Them.
Thanks
Old Jun 27, 2008 | 07:50 PM
cossie604's Avatar
cossie604
The inlet cam should have grooves machined into the bearing journals...exhaust cam doesnt.
Old Jun 27, 2008 | 08:13 PM
SWIFTY's Avatar
SWIFTY
Thanks Ill Have A Look Is That The Only Way Off Knowing And Is That The Only Difference???
Thanks
Old Jun 28, 2008 | 05:56 AM
As said inlet has scrolls on the bearing suraces, also inlet is LYD4 YN0011, exhaust is
LYD2 YN0011.
Old Jun 29, 2008 | 11:51 AM
SWIFTY's Avatar
SWIFTY
thanks
i have 4 cams as i have to heads to build one good one.
i have used the best 2, one with scrolls as the inlet and one witout ext but both num are lyd4
and on my 2 other cams the num are ldy1 and the other ldy5
Old Jun 29, 2008 | 01:05 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Thanks
Capital letters...
Old Jun 29, 2008 | 01:28 PM
cossie604's Avatar
cossie604
^^ What Do You Mean, I Dont Understand Your Post?
Old Jun 29, 2008 | 02:21 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Not a stupid question when you dont know the answer
I'll be keeping an eye on this thread as i'm unsure too.
Reason being i bought a stage3 sapph and was unsure if a diferent camshaft was fitted or just the standard.
Going to replace my cam followers shortly so will have a look then.
2wd and 4x4 cam shafts are different aswell eh??
Old Jun 29, 2008 | 04:59 PM
2wd and 4wd the same, just 2wd use a spacer at the front.
Old Jun 29, 2008 | 05:44 PM
SWIFTY's Avatar
SWIFTY
Originally Posted by TurboShed
Capital letters...
????? whats that mean ?????
Old Jun 29, 2008 | 09:47 PM
LHD220Turbo's Avatar
LHD220Turbo
i think he means you start every word with a capital
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
