Help needed :(
Old Jun 26, 2008 | 01:45 PM
XRT_si's Avatar
XRT_si
Default Help needed :(
Just changed the injectors (from Greys to Blacks) and changed the chip and wired in closed loop and now the car wont start
Its getting a spark, and showing good fuel pressure on the gauge though?
Sounds like the injectors are 'clicking' (louder than usual), and turns over nicely.
Is it more likely to be the injectors or installation of the chip?
Can I quickly and safely try the old chip even though they are not for these injectors?
Any suggestions or anyone had similar?
thanks
Old Jun 26, 2008 | 02:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
check your wiring for the closed loop and the chip installation.
you could put in your old chip just for a quick check.
Old Jun 26, 2008 | 04:37 PM
XRT_si's Avatar
XRT_si
Sorted now cheers
Old Jun 26, 2008 | 04:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by XRT_si
Sorted now cheers
So what was it then ?
Steve.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
