ZVH finaly started
Jun 25, 2008 | 09:47 PM
ZVH finaly started
just to let everyone know, after 5months hard work the zvh has sprung into life, got it satrted tonight and revs nicely and freely,
well happy
Jun 25, 2008 | 09:48 PM
sweet man did you build it yourself?
Jun 25, 2008 | 09:58 PM
Good stuff! now get 1000 miles on it and then get it set up!
whats the spec? what head gasket did you use?
Jun 25, 2008 | 10:17 PM
yeah built it myself, with help of a few mates knowlege,
its a 1.8zetec bottom end, standard rods/pistons (pistons skimmed) arp bolts,
head has mild ported/polish newman camshaft, dble valve springs piper pulley,
turbo is st2 maybe st 3 T3
alloy rad and intercooler
superchiped ecu,
hoping for around 150bhp ATW safely
what yous rekon ???
Jun 25, 2008 | 10:19 PM
Is it MFI or EFI? Should piss 200bhp really.
Jun 25, 2008 | 10:36 PM
deffo more than 150 plus your probaly get loads more torque
Jun 25, 2008 | 10:38 PM
woops yeah its unfortunitly still on mfi
Jun 25, 2008 | 10:40 PM
Well you'll be limited to whatever the metering unit will fuel you to
That's most likely to be your limit before anything else.
Jun 25, 2008 | 10:50 PM
mates running ovr 180bhp ATW stil on mfi
Jun 25, 2008 | 11:28 PM
with a 5th injector on mfi mine was rr at 267bhp. (2.1 tho)
Jun 26, 2008 | 12:22 PM
230bhp S2 in the making!!
are they standard zetec pistons? (cast) need to be a bit ginger on what boost you set it at. Im doing a 2.1 over this winter so I will be asking you for some advice if that ok matey???
Jun 26, 2008 | 03:36 PM
sure thing matey, yeah itl be running under a bar, appaerntly a bar is around the limit for standard pistons
Jun 26, 2008 | 04:11 PM
Theres a big spread in the new fast ford on the whole zvh thing
read it earlier lots of info
Jun 26, 2008 | 05:41 PM
im using c20 ex pistons the early type as there forged ill find the part code if you want and mine only cost me Ł40 off ebay.
Jun 26, 2008 | 08:23 PM
My S2 before I broke it was recorded at 265bhp at the wheels with a 5th and 6h injector on MFI!
Jun 26, 2008 | 08:57 PM
Mine did 155 atw standard internals 1.6 MFi I'd hope to breeze 150 with your spec
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
