fiesta ecu on mfi? will it work?
Old Jun 25, 2008 | 07:01 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default fiesta ecu on mfi? will it work?
can i use a frst ecu on mfi? cuz i think mine is faulty cheers (silver ecu)
Old Jun 25, 2008 | 07:13 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No
Old Jun 25, 2008 | 07:15 PM
XRT_si's Avatar
XRT_si
Your doing well if you can get it to fit
Old Jun 25, 2008 | 07:37 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
the clue is in the name........DOH
Old Jun 25, 2008 | 07:39 PM
XR2's Avatar
XR2
ERST: Bosch KE-Jetronic with ESC-II ignition
FRST: Ford EFI with EDIS
Absolutely NO interchangable parts
Old Jun 25, 2008 | 11:48 PM
TuRbO-CaB-LaD
clears tht up cheers
162
Dec 25, 2019 09:43 PM
EoinXR3
Sep 7, 2015 05:44 AM
gingerturbo
Aug 11, 2015 09:44 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
