2.0 Zetec Turbo block
Old Jun 23, 2008 | 07:51 PM
JamesS2RS's Avatar
JamesS2RS
Default 2.0 Zetec Turbo block
2.0 zetec block
JE Pistons
Eagel Rods
8.7.1 CR Can be lowered if needed with Focus Rs Head gasket or ferriday racing gasket.
Standard 2.0L Silver zetec head
New Oil pump
New big end ect ect
was built 3000 miles ago only removed on friday for new project and was working 100%
Collection only
Head and block are split and i have no rocker cover
all in very good condition
£800.00 open to good offer.
Jim
Old Jun 23, 2008 | 08:01 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
what you going for now then james ????. has it got uprated bolts etc too and what sorta power is this good for ????. with a diff head gasket have you any idea what comp ratio itll be ????.
dave
Old Jun 23, 2008 | 08:09 PM
JamesS2RS's Avatar
JamesS2RS
Im going for a high powered 1.6 for a little project.
Ferriday can do what ever you want as low as 7.5.1
It has all arp bolts inc head bolts
This setup with the right cams should see you into 340-350bhp with the right setup & ecu
i was using it as a 2.0 Zvh and making 298bhp & 360ftlb @ 26 peak psi and holding 24.
Good engine and i can supply most of the parts for the same price for zvh @ 7.5.1
Jim
Old Jun 23, 2008 | 08:41 PM
SWITCHBLADE
doesnt a zvh bottom end have oil gallerys blocked mate ????. so the same bottom end you have used with a cvh head will be 7.5:1 ????.
cheers
dave
Old Jun 23, 2008 | 09:18 PM
JamesS2RS's Avatar
JamesS2RS
They can be removed no problem matey.
The parts i have will give 7.5.1 on a CVH head. It's the same spec as turboboss run he gave me all the parts numbers and contacts to buy the parts.
This engine is a very good spec and cost me around 3k for all the bottom end work, labour and parts.
Jim
Old Jun 23, 2008 | 09:24 PM
SWITCHBLADE
as it stands, is the bottom end in zvh spec then ie oil gallerys blocked ready for a cvh head, can you pm me full spec of the bottom end and what would be included in the sale if i want it for a zvh ????.
cheers bud
dave.
Old Jun 23, 2008 | 09:25 PM
JamesS2RS's Avatar
JamesS2RS
Pm on its way
Old Jun 23, 2008 | 09:41 PM
JamesS2RS's Avatar
JamesS2RS
This is the full spec of the enigne can be either ZVH or Zetec for very little work:
2.0L Silver Top Zetec Bottom End
All blanked up for ZVH
Baffled Sump
Oil Return Fitted to the Sump
Ferriday Racing comp plate 7.5.1 Or not needed if you run a zetec head the cr will be 8.7.1
JE Pistons
Eagle Rods
New Mains
New oil pump
New Big ends
New Thrust washer
New Gaskets
New Water pump
New oil Jets
Polished Crank
Balanced crank
ARP Rod end bolts
ARP Head Bolts
Water pump plate
ZVH engine mount (may need the rubber mount replacing)
Dipstick and Tube
Oil Changed every 1500 miles run in for 1000 miles it like new never had any problems with it and worked very well
All you need is a new head gasket put your head on and your away.
100% prefect working order
Old Jun 23, 2008 | 10:08 PM
turboloon's Avatar
turboloon
who was it built the btm end any recipts to go with the work done..?
Old Jun 24, 2008 | 07:57 AM
JamesS2RS's Avatar
JamesS2RS
The engine was built by Dr Auto's in Bishop's Stortford a local Rs / Cosworth tuner
All the machining work was done by Ash Poles in Bishop's Stortford
I may have one or two recipts but i never really bother keeping them.
Cheers,
Jim
Old Jun 24, 2008 | 09:35 AM
ukgaz's Avatar
ukgaz
This is sooo cruel! i need money lol
Old Jun 28, 2008 | 07:54 PM
lewismk1's Avatar
lewismk1
Still for sale?
Old Jun 28, 2008 | 09:21 PM
FULLBORE's Avatar
FULLBORE
also interested if this is still for sale.got money waiting
Old Jun 30, 2008 | 08:04 AM
JamesS2RS's Avatar
JamesS2RS
Sold to Switchblade aka Dave cheers matey
Old Jun 30, 2008 | 04:50 PM
SWITCHBLADE
thanks mate, was good to meet ya buddy, dont forget the bits though lol
dave
robnock
21
May 13, 2019 05:29 PM
big_Rad
Sep 15, 2017 09:36 AM
cossirob
Aug 29, 2015 03:23 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
