oil pump...:(
hello,
i have just finished my saph and i was rolling with 3000rpm when the oil pump left me and destroyed anything.... arrow con rods wiseco pistons... i opened it today and i'm sending you some photos...
the oil pump i bought it new from U.K. and i heard and other friends that had problems with these pumps... Now i started rebuilding the engine from the beggining...
i want to hear your opinion for the oil pump! tell me where to buy and not have these problem again!
thanks
thanks
I don't know where to suggest offhand but I just had to write and say how terrible an experience this must be. I remember starting mine after a rebuild and worrying. Good for you for getting straight back into sorting it out!
Know andyg had a problem at some point,but cought it in time,my advice use a used pump that you know has done a few miles,but is 100% servicable
cheeRS stu
cheeRS stu
There have been others with similar problems, it's disgusting as the pump is not a hard part to get right, especially how these seem to fail.
I am so sorry for you, it's so bloody expensive as well, think I will will be refurbing my existing pump, not as cheap as a new pump as casing has to be machined as well as rotor.
yes i had a greddy oil pressure gauge i was controlling it when i was driving but it hasn't gave me any signal of low pressure... Everything happened in a sec!
here is a photo how it was before blowing....
i will post pics of the rebuild in a post on restoration section
what brand is it on the pump ? Was the engine cold when it happened ? I know the cosworth pumps flows alot of pressure on my engine so im extra careful when its cold or this might happen I think =)
hello,
thanks
thanks
Mark
PassionFords Creator
deathrider666
Sep 28, 2015 06:12 PM
