do they still Q plate cars?
Old Jun 20, 2008 | 06:59 AM
B19LRW's Avatar
B19LRW
Its Broken.....
Default do they still Q plate cars?
i have spotted a unregistered shell, but i dont want it if its on a Q....
the seller told me it will need a SVA, but not if it will be Q'd. ( as its built from loads of parts (that aint new)
ta..L
Old Jun 20, 2008 | 07:19 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Yes Q plates are still issued
SVA and registering a new car:
http://www.direct.gov.uk/en/Motoring...cle/DG_4022486
SVA requirement works on a points system. To keep the original identity, you need 8 points.
Original chassis/shell = 5 points
Suspension = 2 points
Both original axles = 2 points
Transmission = 2 points
Steering assembly = 2 points
Engine = 1 point
as the shell aint registered it will be Q'd, as im guessing u can only have 5 points from the cars chassis/body if u went straight for a registration.
If u sva, youd probably get an age related plate.
wont be a problem its not like a kit car! its a normal production car so should fly through, as all the sva is is a through mot basically
best give them a call mate, they can tell u for sure, get it in writing as wel!!!
Old Jun 20, 2008 | 07:22 AM
JayCC's Avatar
JayCC
a little off topic, but how did the ford puma in the last Performance Ford, get an 08 plate on it?
Old Jun 20, 2008 | 07:28 AM
adam151082's Avatar
adam151082
he got a 08 plate cos its all new parts from ford (where posible) think it said your aloud 1 old part so he got the engine. how come if cars get a re-shell they dont get a Q plate?
Old Jun 20, 2008 | 07:30 AM
B19LRW's Avatar
B19LRW
Its Broken.....
cheers lee, i have a saff donor, and will be using all the suspension etc... i wonder if i can use the id of that?
Old Jun 20, 2008 | 07:31 AM
JayCC's Avatar
JayCC
thanks
Old Jun 20, 2008 | 11:09 AM
xr4x4rs's Avatar
xr4x4rs
the only way they will issue an id is if you had a reciept from ford for a brand new shell
if you dont then it will be q plated
Old Jun 20, 2008 | 05:05 PM
cala's Avatar
cala
i have an fiesta cosworth shell , brand new unregised dont know what that will go on ,, i i am selling it ,,
Old Jun 20, 2008 | 06:28 PM
jimmy/taylor's Avatar
jimmy/taylor
Q plates are okay for the M.O.T test .no emissions test.the only check is for visible smoke.
Old Jun 20, 2008 | 10:39 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
well as said if you can get 8 or more points from the same vehicle then u can use that reg!!!
ie if u used the engine, axles steering etc for one car!
Old Jun 21, 2008 | 03:01 PM
AndyPen's Avatar
AndyPen
Yep - that info is good
mpales
Ford Escort RS Cosworth
Aug 11, 2015 11:46 AM
xr4x4rs
Aug 6, 2015 09:03 PM
onionlover
Aug 6, 2015 03:20 PM
creator
Aug 2, 2015 12:24 PM
