What power how much boost
Old Jun 15, 2008 | 06:27 PM
robbob's Avatar
robbob
Default What power how much boost
Hi ive recently finished my series one, done a bit to the engine, was just wondering what boost i should be running with my spec and what sort of power it will be when set up spec as follows.
1.9 american tall block cvh
stage 3 head
kent cam with vernier
cone filter
group a coil
chipped ecu
full scorpion exhaust
erl fith injector
turbo unknown hybrid
full front mount intercooler with twin fans
Old Jun 15, 2008 | 08:12 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Let your mapper decide when he's got it on the Rolling road!
all depends where it starts to detonate i'd say!
Old Jun 15, 2008 | 08:45 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
wudnt run more than 14 psi on mfi management 2 keep it safe.17 psi at most.get it set up on the rollers so its all pukka
Old Jun 16, 2008 | 03:50 PM
addiction's Avatar
addiction
why do you say that? mfi can easily and safely fuel to 18 psi!!
Old Jun 17, 2008 | 06:34 AM
rickbartlett
G911 TTA
just quoting wot i was told by jamie at jamsport mate
Old Jun 17, 2008 | 07:57 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
14psi on a 1.6 and 14psi on a 1.9 aren't the same thing.
I think 1 bar will be about your limit, from what i've seen. You'll either start to run lean or if you have a great metering head, you'll be close to the limit of your rods (if the turbo flows enough).
Old Jun 17, 2008 | 11:33 AM
rickbartlett
G911 TTA
1 bar is 14.5 psi
Old Jun 17, 2008 | 07:24 PM
addiction's Avatar
addiction
well my heavily modded 1.8 runs 18 psi with no bother at all and has been doin so for over 4 years now!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
