Fuel line removal
Old Jun 14, 2008 | 02:58 PM
cosrep's Avatar
cosrep
Default Fuel line removal
How do I remove the fuel line from the fuel rail on a 1990 2wd, the one that has a chrome circular fitting with what looks like a spring on the inside..? Dont want to force it and break it.
Old Jun 14, 2008 | 03:58 PM
dazzle740's Avatar
dazzle740
sorry mate but the removal of the the fuel line from the rail requires a special tool i had my local tuner do mine
Old Jun 14, 2008 | 04:26 PM
The tool is a air con pipe disconnector of the relevant size, it comes either hinged or in two parts but wraps around the pipe then you push it into the connector and it expands the wire ring inside so you can pull it apart, as I say these are used on air con fittings as well.
ebay might be worth a go.
Old Jun 14, 2008 | 04:49 PM
RS SHAUN's Avatar
RS SHAUN
i used a jubilee clip with the nut cut off, it worked fine
Old Jun 14, 2008 | 04:57 PM
mechanic28's Avatar
mechanic28
this ind of worries me!as i only have a jubilee clip holding the fuel line to the rail!the previous owner must of binned the o.e fitment
Old Jun 14, 2008 | 06:15 PM
LHD220Turbo's Avatar
LHD220Turbo
this is what you'll be needing
http://www.justoffbase.co.uk/Air-Con...=9&category=90
Old Jun 14, 2008 | 07:58 PM
cosrep's Avatar
cosrep
Thanks for all the replies, I got it done this evening with the jubilee clip trick but ordered a set of air con disconnects for the future
1300gt
Sep 7, 2015 12:06 PM
muffster
13
Sep 3, 2015 09:40 PM
3doorcozmess
Aug 21, 2015 11:17 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
