turning the engine manually
Old Jun 13, 2008 | 06:02 PM
cossie.con's Avatar
cossie.con
Talking turning the engine manually
hi guys just wondering if the starter motor is engaged onto the fly wheel would this make the crank impossible to turn by hand as my bottom pully seems to be stuck solid and i cannot turn the crank either way p.s the timing belt is not fitted so cam timing should not be an issue am i correct
Old Jun 13, 2008 | 06:29 PM
Mark V8's Avatar
Mark V8
If the head and cams are still on the pistons are probably jammed against the valves
Mark
Old Jun 13, 2008 | 06:33 PM
cossie.con's Avatar
cossie.con
Talking
the problem im having is that the pistons are at tdc so surely the next stroke would drop them away from the valves,or can the really jam enough to stop complete movement sorry if i sound a little daft i prob am cheers
Old Jun 13, 2008 | 06:38 PM
Mark V8's Avatar
Mark V8
I would take the head off to avoid any more damage, I see your reasoning on TDC but the head will need to come off anyway.
Mark
Old Jun 13, 2008 | 06:42 PM
cossie.con's Avatar
cossie.con
Talking
yes as i thought never mind eh thanks for the swift reply
Old Jun 13, 2008 | 06:48 PM
cossie.con's Avatar
cossie.con
Talking
The Underdog
29
Sep 7, 2015 09:49 PM
mick.slinn
Aug 10, 2015 01:38 PM
tankybaby66
Aug 9, 2015 07:13 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
