were can i get a std new clutch cover?
im going to go for alcon 6paddle but use std cover i can get the clutch ok but were can i get std cover and what do they go for cheers
You can get the standard clutch cover direct from Ford. However, I wouldn't recommend it, as they have switch to using a cheap version that is not much good for anything beyond standard power
. It will work, but it won't last very long before it needs replacing (a few thousand miles of hard use).
Roosie, the Full Alcon kit (cover & plate) was lighter than the std clutch that came out when I originally switched over to paddle - just fit a new cable at the same time (you look like you need one ayway, lol).
. It will work, but it won't last very long before it needs replacing (a few thousand miles of hard use).mike ive jut text you about a alcon clutch if u had one in stock?
