can any one put me in the right direction
Old Jun 11, 2008 | 07:07 PM
cossiedave's Avatar
cossiedave
Default can any one put me in the right direction
on my escort cos how to make the rev conter work proper with coil pack
Old Jun 11, 2008 | 07:12 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Have you done the Rev counter mod? Where you add a small wire across two terminals on the back of the PCB?
Si
Old Jun 11, 2008 | 07:13 PM
cossiedave's Avatar
cossiedave
no m8 can you tell me
Old Jun 11, 2008 | 07:27 PM
cossiedave's Avatar
cossiedave
dose any one have any pics of what to do thanks
Old Jun 11, 2008 | 07:33 PM
KSA-Cossie's Avatar
KSA-Cossie
Whats your e mail m8 and i'll send it to you.
Old Jun 11, 2008 | 07:36 PM
Si B's Avatar
Si B
Good man, I know what was done to mine but can't explain it to Dave and don't have the photo any more.
Knew someone on here would
Old Jun 11, 2008 | 07:37 PM
KSA-Cossie's Avatar
KSA-Cossie
Stu was the good man who sent it to me.
Old Jun 11, 2008 | 08:23 PM
cossiedave's Avatar
cossiedave
pritchardc4@aol.com thanks chap
Old Jun 11, 2008 | 08:30 PM
KSA-Cossie's Avatar
KSA-Cossie
Hopefully you've got it now m8.
Old Jun 11, 2008 | 08:50 PM
cossiedave's Avatar
cossiedave
not yet m8 can you try again please
Old Jun 11, 2008 | 08:59 PM
KSA-Cossie's Avatar
KSA-Cossie
Sent again m8.
Old Jun 11, 2008 | 09:02 PM
Bart's Avatar
Bart
Can you send it also to me? Have the same problem.
Thanks
Old Jun 11, 2008 | 09:04 PM
KSA-Cossie's Avatar
KSA-Cossie
Email addy m8 ?
Old Jun 11, 2008 | 09:14 PM
cossiedave's Avatar
cossiedave
my computer wouldnt let me in to what you sent m8 can you send it to me through this sit thanks
Old Jun 11, 2008 | 09:15 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
bart@springfield.com
Old Jun 11, 2008 | 09:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Not sure how,its a pdf file ?
Old Jun 13, 2008 | 04:24 PM
paul16v's Avatar
paul16v
Monte 087
Would also like to know this, i fitted an RS2000 revcounter in my clocks as i was told this would work but it was exactly the same
Old Jun 13, 2008 | 04:57 PM
Dave Henshall's Avatar
Dave Henshall
if you fitted a rs2000 clock set, then you dont need the coilpack driver from the msd board,,, use the original green wire from the neg of 1 side of the coilpack - as per a rs2k is wired.
Old Jun 13, 2008 | 05:03 PM
bpspa's Avatar
bpspa
download the latest adobe acrobat reader from here and the pdf file will then work
http://www.adobe.com/products/acrobat/readstep2.html
Old Jun 13, 2008 | 05:53 PM
Or if any other tacho's get problems buy a tacho driver
DixieTheKid
11
Jun 6, 2020 11:20 AM
tib2220
Sep 14, 2015 12:33 PM
Cossikev
Sep 13, 2015 02:00 PM
Si B
Sep 12, 2015 06:49 AM
focus2351
Sep 9, 2015 09:33 PM
