swopping gearbox casings
Depends on how familiar you are with gearboxes and if the 5th gear comes of easily or not.
If you haven't done it before, let someone show you who knows what he/she is doing.
Can be done in a couple of hours providing that the 5th gear doesn't stick on very bad.
Have a look at my rebuild thread which will show you what to expect inside the gearbox (rebuild pics near the bottom of the page).
https://passionford.com/forum/restorations-rebuilds-and-projects/196934-engine-and-gearbox-rebuild-time-update-24-08-a.html
You will proably need a decent puller to remove the 5th gear and apart from that its quite straight forward. If you just want to swap over the case for the series one engine mount then you can leave the shafts and selector mechanism in the lower gearbox casing.
You can get a gasket set from here...
http://www.maintrainltd.com/
One thing to remember is take note of the direction of the slot in the end of the 5th/reverse gear selector rod. When you are rebuilding the box and fitting the 5th gear selector you will have to turn the selector rod clockwise before tightning the pinch bolt. If you dont turn it you will have no 5th or reverse gear or no gears at all as it will jam the selector mechanism.
fifth gear can be an absolute C*&T!!
i use a puller that has two wide flat legs that go around both sides of the gear , and two 8" g glamp that i hold the legs together with. With a buddy holding the g clamp and bracing himself , i use an electric impact wrench and much swearing
chowfornow
14
Jan 5, 2019 09:01 PM
muz
Sep 30, 2015 08:29 AM
