no power to fuel pump relay ?? rs turbo
Old Jun 10, 2008 | 07:39 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
Default no power to fuel pump relay ?? rs turbo
hi as above.
a mate has come to start his fiesta after 6 months storage, restoration starts tommorow.
but it wont start, there is no positive feed to the fuel pump. when a direct feed is put to the pump the car will start !!
i assume the red relay is the fuel pump relay ? ( same as pink on my s2 escort) there is no power to the relay.
any ideas what the problem is ? it drove in the garage ok,
is there a fuel cut off switch some where on the car or something ?
please help
thanks
Old Jun 11, 2008 | 05:34 PM
gavin1165's Avatar
gavin1165
relay should be green under the drivers side dash and there is a fuel cut off in the pasenger side foot well behind the little flap
Old Jun 12, 2008 | 10:40 PM
Turboboy67's Avatar
Turboboy67
Depends if its an early or a late FRST, my one is an early (pre-93) and it has 2 relays one was yellow and one was grey/metal, change both to start with.
Fuel cut off switch is behind flap in passenger side footwell, just make sure button is pressed down on it.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
