is a rs turbo fuel pump same as xr3i?
Old Jun 10, 2008 | 05:54 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default is a rs turbo fuel pump same as xr3i?
Old Jun 10, 2008 | 06:22 PM
boothy's Avatar
boothy
i was told they were the same,but if you go over 200 you need to change it to a cossy one,i think
Old Jun 10, 2008 | 06:52 PM
stembo21's Avatar
stembo21
i have a rs turbo one if you interested 15 quid
Old Jun 10, 2008 | 08:56 PM
MarkXr's Avatar
MarkXr
No it isn't. The RST pump can deliver more flow then a XR3i pump.
Cosworth external pump is even a better option though.......
Old Jun 10, 2008 | 09:09 PM
TuRbO-CaB-LaD
im on 200bhp at wheels, wud a xr3i cope temporaily?
im intested in the pump 4 sale, is it in good condition cheers
Old Jun 10, 2008 | 09:18 PM
MarkXr's Avatar
MarkXr
It will make the car drive for sure. Just be carefull that it doesn't run lean when driving hard! (or else it could turn out to be an expensive fuel pump. )
Old Jun 10, 2008 | 09:41 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
pumps are 100% the same,check the part number!tho they do need up rating for 200 bhp like said above!
Old Jun 11, 2008 | 06:52 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
why do you need to upgrade them for over 200bhp ?
Ive never upgraded my XR3i fuel pump and thats still delivering the goods at over 200bhp
Old Jun 11, 2008 | 09:54 AM
MarkXr's Avatar
MarkXr
Where did you check the part numbers? For replacement they give the same number (and pump) but originally fitted they were different. At least the original Dutch ones are.
Could be that the XR3i with KE Jetronic also used the RST pump but on my K Jetronic XR3i there was definately an other (slightly less powerfull) pump.
Old Jun 11, 2008 | 02:45 PM
gaz s1's Avatar
gaz s1
ive been using an xr3i pump on mine for the last eight years running 206 bhp and many rolling road setups with no problems with fuel delivery at all
Old Jun 11, 2008 | 02:53 PM
orion88's Avatar
orion88
yes theyre the same and its advised to upgrade the fuel pump it aint a necessity dependant on the boost levels your running.i personally wud run a cossy pump
Old Jun 11, 2008 | 04:24 PM
juffer's Avatar
juffer
im running 267bhp and using a standard pump with no probs at all
matt
Old Jun 11, 2008 | 05:43 PM
bad boy rs's Avatar
bad boy rs
for a 140 quid you can get a group a jobbie from matt lewis
Old Jun 15, 2008 | 12:50 PM
juffer's Avatar
juffer
matt
ok just an update, i fitted an afr guage the other day and my car really badly leans out at 5000 rpm adjusted the fuel and made no difference at all so this statement i made is compleate nonsence, ooopps sorry lads
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
