Replace orig. ECU with Gotech unit
Old Jun 8, 2008 | 09:03 AM
S2_RST_DK's Avatar
S2_RST_DK
Default Replace orig. ECU with Gotech unit
I am about to replace the original ECU with a Gotech one from Jamsport. But i am not 100% sure if it is the ECU with the white or green label i have to replace with the Gotech.
Looking at it yesterday shortly, i think that it is the one with the green label, but just wanted to ask some PF´if is the right one.
And where have you installed the ECU ? same place as the orig. or somewhere under the dashboard ?? (Gotech manual says somewhere dry )
Henrik
Old Jun 8, 2008 | 09:09 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Surely an aftermarket ECU would be replacing both ECU's?
Old Jun 8, 2008 | 10:11 AM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
im sure the go tech does get rid of both
Old Jun 8, 2008 | 02:53 PM
bezo's Avatar
bezo
powered by K26
i take it your still runing the MFI set up then?
yer they replace both, as when gotech is fitted youll be running efi and wont need them.
and sick it in your glove box, thats where mines going.
Old Jun 8, 2008 | 07:13 PM
S2_RST_DK's Avatar
S2_RST_DK
OK thanks
The engine has already been converted to EFI and i do have the new loom and Gotech ECU, but for some reason the 2 old ECU´s are still in the car.
They will be removed asap.
Old Jun 8, 2008 | 08:14 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
yep replaces both old ones, ive got mine in the glovebox now with all the wiring exiting through the rear of the glovebox.
dave
Old Jun 9, 2008 | 08:15 AM
robj20's Avatar
robj20
I had it installed on saturday and they say the idle still runs off the old ecu and ICV.
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
Jan 5, 2016 01:16 PM
Tank Mike
Sep 14, 2015 03:56 PM
NC53
Sep 13, 2015 03:05 PM
RSmark84
Sep 13, 2015 01:29 PM
