Heavy Vibrating from gearbox area?
Old Jun 4, 2008 | 11:36 PM
XRT_si's Avatar
XRT_si
Default Heavy Vibrating from gearbox area?
As above, RWD Saff, clutch was recently replaced (as in last week) and it's starting making a heavy vibrating noise below 3000rpm.
It does it only when in gear or pulling away etc... i.e. not on the spot and revving.
It sounds just like the when the doughnut bush on the prop went on my old BMW E36, but I am told Cossies dont have the same set up?
What is it most likely to be?
Hopefully just the exhaust rattling but thinking ahead.
Old Jun 5, 2008 | 06:47 AM
RWD Pete's Avatar
RWD Pete
yes mate the prop has a rubber coupling this may of split
Old Jun 5, 2008 | 07:39 AM
fraser9764's Avatar
fraser9764
propshaft centre bearing or a tight / fucked UJ would be my guess.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
