Tips on getting petrol out of fuel tank
Old Jun 4, 2008 | 11:39 AM
RS_Ant's Avatar
RS_Ant
Default Tips on getting petrol out of fuel tank
As some of you know i was in a crash yesturday and ive now got a hire car
There's £30 worth of fuel in my KA and the KA aint ever gonna use it because it's fucked and im not leaving £30 worth of fuel in it especially how expensive fuel is ATM.
Anytips on removing it from the tank??
Ive already tried cyphering the fuel with a hosepipe and had no luck.
Any tips would be apreciated
Old Jun 4, 2008 | 11:40 AM
R5FORD's Avatar
R5FORD
jam a screw driver into it and have a bucket handy
Old Jun 4, 2008 | 11:41 AM
rsnissan's Avatar
rsnissan
run the fuel return to a container and turn the pump on
Old Jun 4, 2008 | 11:43 AM
fraser9764's Avatar
fraser9764
need a siphon pump really, are ka's electric pumps? if so run 12v to it and pull a pipe off
Old Jun 4, 2008 | 11:44 AM
The Youth.'s Avatar
The Youth.
that doesn't work on some modern cars as if they don't see fuel pressure after a set time then it switches the pump off, mk2 mondeos do this as I found out recently
as to another way, just ask a pikey they have it down to a fine art now!!
steve
Old Jun 4, 2008 | 11:50 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Use a smaller diameter pipe to syphon the water aswith a hosepipe, it needs some serious sucking to draw the intial head of fuel to set the syphon up. also make sure it really is at the bottom of the tank by measuring the pipe your inserting.
Old Jun 4, 2008 | 11:59 AM
RichieST's Avatar
RichieST
disconnect the fuel feed in the engine bay, run a wire from the positive of the battery to the positive terminal on the pump, and let it flow out
Old Jun 4, 2008 | 12:27 PM
cozmeister's Avatar
cozmeister
More boost Igor!
steve
Nah, they just take the whole car...
Short of dropping the tank mate, I can't offer any intelligent suggestions, as I expect the pump's not gravity fed.
So there's about a gallon in it then?
Old Jun 4, 2008 | 12:32 PM
TurboShed's Avatar
TurboShed
Cossiemodo
There's £30 worth of fuel in my KA and the KA aint ever gonna use it because it's fucked and im not leaving £30 worth of fuel in it especially how expensive fuel is ATM...
That last line REALLY doesn't make any sense y'know!
Now, "I'm not leaving 5 gallons in it, especially how expensive fuel is ATM" that would make sense
Old Jun 4, 2008 | 12:36 PM
focusjohn's Avatar
focusjohn
St.
We recently done this on a mk2 mondeo what we done is take off the feul return and put a hose onto it and put hose intoa contianer and started engine seemed to work fine when finished place return pipe back on.
155lee
Oct 27, 2015 04:55 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Si B
Sep 12, 2015 06:49 AM
