turbo over heating please help
Old Jun 4, 2008 | 09:06 AM
orion88's Avatar
orion88
Default turbo over heating please help
the water pipe snapped of the bottom of my turbo yesterday however there was a stub left where i could get the pipe back on
so i did this but now after refilling my rad water the turbo is glowing red after a drive and it is not boosting at all
is this due to the water pipe?
do i need a new one to replace the old one?
im going to replace it anyways but i need something to keep me goin till the new one arrives
any ideas any one?
Old Jun 4, 2008 | 01:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds to me like you overheated the Turbo/engine when you lost your water mate, so long as the water is circulating with your pipe as it is it should be fine!
Old Jun 4, 2008 | 02:08 PM
orion88's Avatar
orion88
waters in it tho and its still not boosting and the turbo is over heating?
any ideas?
Old Jun 4, 2008 | 02:15 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
its fooked lol can u hear the turbo spinning up?
Old Jun 4, 2008 | 02:24 PM
orion88's Avatar
orion88
lol it was before i bough it
yea it spins up and the dumpvalve goes of but the car goes no where
thinkin maybe timing but the water pipe falling of would not have done that
Old Jun 4, 2008 | 02:43 PM
RichieST's Avatar
RichieST
you say its not boosting at all but the dump valve 'goes off'?
Old Jun 4, 2008 | 02:54 PM
orion88's Avatar
orion88
well it boosts but the car goes no where
Old Jun 4, 2008 | 05:54 PM
JamesS2RS's Avatar
JamesS2RS
When the pipe for the turbo went was the engine running? If the engine got too hot from losing all the water when the pipe went you could of caused a number of issue with the block. Does it run ok on tick over? You could of done the rings hence why the boost pressure wont build up. Take it to a garage for a pro to look at.
Jim
Old Jun 5, 2008 | 10:15 AM
orion88's Avatar
orion88
thwe pipe was loose and leaking but when i pulled it off water went every where so im guessing that it aint cooked the block
it feels like timing cos it boosts now and again 1st is fine second is dead 3rd varys and 4th an 5 are no fgood either
really annoyi g me now tho.i took the oil cap of and it ran exellantly boosted well and everything i then put it back on and it went crap again so i took it back of and it was still crap.is it possible i have a blockage?
Old Jun 5, 2008 | 10:20 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
When you take the oil filler cap off you introduce a vacuum leak which will normally cause these to cut out.. if it 'fixes' your problem, then that's a pointer to something else that's wrong.
Your turbo isn't overheating, they're supposed to glow (when ragged).. If your timing has slipped seriously and its retarded your spark timing, then perhaps that'd cause unnecessary glowing (eg, under normal use)...
I'd get a qualified mechanic to look at it.. preferably someone that specialises in these cars.. the turbos dont require the water cooling.. (although losing all your water from a broken pipe isnt going to help your engine).
Smartdj.'s Avatar
Smartdj.
m8 get an expert 2 have a look
Old Jun 5, 2008 | 10:39 AM
Smartdj.'s Avatar
Smartdj.
sure u havent split a boost pipe......i found a hole in 1 on my renault 5 it was a split 4mm wide but wasnt enough 2 make the cr stall...
Old Jun 5, 2008 | 10:50 AM
orion88's Avatar
orion88
nah its definately not the pipes
i took it for a spin earlier been gentle on it and i put my foot down a few times and it boosted perfectly
cars really pissing me off atm
it shouldnt run if i take the cap of should it?
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
