Boost Controller
Old May 29, 2008 | 08:29 AM
MorryRS's Avatar
MorryRS
Default Boost Controller
Im currently running my RS with a amal valve and wonder if it would be ok to run a mechanical boost controller
Can you does this with the S2 , im still on MFI too
Old May 29, 2008 | 11:53 AM
T28 RST's Avatar
T28 RST
Ok then
A bleed valve will be perfect as long as its set and LEFT ALONE
Old May 29, 2008 | 02:19 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Make sure you get a Brass one, NOT an Alloy one.
Old May 29, 2008 | 02:32 PM
MorryRS's Avatar
MorryRS
Is there any specfic ones to get that are better than others?
Why brass ones?
Morry
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
