im having problems with my car not starting unless i use easy start. once its started using easy start it will run and drive fine till i come to a junction and it will stall and will not start unless i use easy start again!
any ideas?
juffer
Sounds like dodgy wiring to the easy start. almost as if it has a broken connection between the barrel and the easy start unit, but the connections after the unit are fine.
