OBD protocol
Old May 28, 2008 | 04:56 PM
podgeywodgey23's Avatar
podgeywodgey23
Question OBD protocol
Has anyone heard of the term OBD2 protocol?? want to buy a guage from PLX DEVICES thats meant to plug & play in cars from 96 onwards. iv an omex 600 in my erst so does that mean it can be plugged in like that to the ecu ? Can it be hard wired if not??
If you dont know what im on about then check out the DM-200 on this link====
http://shop.edoperformance.co.uk/plx...e-p-10773.html
Old May 28, 2008 | 07:05 PM
mentalasanything's Avatar
mentalasanything
OBD2 is a standard for On Board Diagnostics. Basically all cars after around 1996 meet this standard for looging information in their ECU's and then they all have a port which OBD interrogators can request information through using the common OBD protocol. Any gauge that is OBD plug and play wil only fit cars with OBD ports. The omex ECU you have doesn't support OBD therefore you wouldn't be able to use an OBD interrogating gauge.
I wouldn't have said that you could hard wire it into the ECU Either as you need the data storage and protocol on the ECU in the first place, and I beleive the Omex uses a propriatery storage area and the RS232 protocol for interrogation.
I'm sure someone will correct me if I'm wrong but that's how I see it. What gauge you after bud?
Old May 28, 2008 | 07:13 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That's pretty much it - i'm not aware of any aftermarket ECU to support OBD1/2.. (unfortunately).. It's a pretty advanced thing really for an ecu co. to implement with minimal gain for them i suppose..
You could technically get someone to create you an omex<>obd converter.. those plx gauges are niice..
Old May 28, 2008 | 08:14 PM
THEDMAN's Avatar
THEDMAN
Most of the Focus RS boys have Scangauge II's fitted!
http://www.scangauge.com/
Plugs in the OBD II port an does virtually the same as a SECS unit!
Old May 29, 2008 | 10:28 AM
podgeywodgey23
Just rang omex myself ther and they told me it wouldnt work with the 600 series. well bolox to that anyway!!! does anyone know a good guage or small screen that gives all your readings ie AFR, oil pres, temp, throttle pos, that sort of stuff and it looks good on my dashboard??
Old May 29, 2008 | 12:54 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Race Technology make a nice dash..
Old May 29, 2008 | 01:36 PM
mentalasanything
http://www.turbodisplay.com/
I personally will be getting one of these!
Lee
Old May 30, 2008 | 10:28 AM
podgeywodgey23
Rang PLX DEVICES and iv found out that they do make a guage that doesnt use OBD2 protocol its the DM-100.. I reckon its the dogs bolox have a look at the following link and let me know what you think yourself>>
http://www.plxdevices.com/products/dm100/
Old May 30, 2008 | 05:15 PM
mentalasanything
They are really kool. I like the way you can design the gauge too. Wouldn't mind one myself.
Sensors are a bit expensive though, considering you would be paying £100 for the gauge in the first place, £50 for a sensor is a bit steep.
But worth it if they work as well as they look
Lee
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
salsheikh
Jul 30, 2015 08:45 PM
PhilM
Mar 13, 2008 01:09 PM
ST EDDIE
Jun 10, 2006 09:26 PM
