Annoying alternator belt squeak, any ideas?
Ive got an annoying squeak when the engines running which I was told I needed my alternater belt replacing and that'll cure it.
I replaced one belt then after about a month the squeak came back so I replaced it again and low and behold the squeak is back!
Anyone got any ideas as what it might be thats causing it to squeak?
Lee
Lee
Dont know if it will help but i had a simmilar problem with mine and i found the powersteering pump bolts were loose i tightened them up (after changing the belt) and it went away. try that.
id say its not aligned properly, the grease will work temporarily, as will replacing the belt.
just check everything that it revolves around to ensure everything is tight, it would only need one bolt to be the slightest bit loose and something wont sit quite so square to what it should be.
i definatly wouldnt say the belt is to tight as its on a sprung loaded tensioner.
Would be very grateful
Lee
it could also be that the belt that was originally causing the squeek has left some residue on the pulleys which has now transfered itself onto the new belt
this should be fairly easily visable theough and it was much more prevalent on the V belts than the serpentine ones which i think you would be refering to if it's an auto tensioner
Nah never found the problem, did get one of the pulleys (cant remember which one though) but couldnt find anyone to do the job would you believe! Changed the belt a couple of times then sold it...
jonfoc
16
Sep 11, 2018 05:35 PM
