Puma gearlinkage?
Old May 27, 2008 | 10:35 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Default Puma gearlinkage?
I'm sure i've heard of this retro fitted to a S2, I've got a puma as a daily drive at the mo and the gearchange is ace compared to the rst.
Would the puma linkage fit and improve the feel?
Old May 28, 2008 | 06:47 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Originally Posted by jonnyrsturbo
i could be wrong
you can make the puma fit and work and its a excellent gear change, get the two linkages together and use both the escort and puma parts to make it
Old May 28, 2008 | 07:03 AM
Daveysaff's Avatar
Daveysaff
sounds good
Is there a how to anywhere that anyone knows of?
Old May 28, 2008 | 07:28 AM
Turbocabbie
Top Cab !!
Im not aware of a how to being available, but I am aware of a couple of cars that run this setup and it feels pretty slick
Old May 28, 2008 | 10:38 AM
JesseT's Avatar
JesseT
It doesn't need modification or mixing and matching of parts. It only needs to be somehow bolted to the floor as the fixing is very different (no bolt in each corner). Perhaps the Puma's gearchange linkage rear mount would solve this. Some people have shortened the linkages by ~2cm to make the stick more central to the opening in the floor. For tall people it's just better as it is.
Old May 28, 2008 | 10:38 PM
ShandzS1's Avatar
ShandzS1
looks like al be after one........
Old Nov 24, 2008 | 10:33 PM
ShandzS1's Avatar
ShandzS1
Done it, and what a difference!!!
Old Nov 24, 2008 | 10:47 PM
mpf1987's Avatar
mpf1987
BOOOOSSSST
So did u just bolt it on? I'v been thinking about this for mine.
Old Nov 24, 2008 | 10:52 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
wht puma one do u use?
Old Nov 24, 2008 | 11:09 PM
rst in breaking's Avatar
rst in breaking
interesting, is it true people use these with the mtx75 conversions?
Old Nov 25, 2008 | 11:17 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
this is one of my to-do's for the winter for sure.....
Old Nov 25, 2008 | 07:51 PM
ShandzS1's Avatar
ShandzS1
It was a 1.7 linkage, but got told they are all the same.....
It bolts onto the gearbox like normal, and u have to trim the edge of the cradle mount and drill 2 holes through the floor and secure with m6 bolts!
Easy! and so much better than my old worn 16i linkage.
Old Nov 25, 2008 | 10:20 PM
studabear's Avatar
studabear
intresting conversion, luckily mines still really good
Old Dec 10, 2008 | 10:10 AM
javierant3's Avatar
javierant3
I am interested in this conversion , and I have purchased in a breakers a puma gearlinkage, but I noticed that the internal mechanism doesn`t have the return springs that make the gearchange return to the centre position.
What can I do? In the escort mk4 this springs are necessary.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
Ben26
Sep 3, 2015 07:55 PM
