Much Difference ?
Old May 23, 2008 | 05:50 PM
podgeywodgey23's Avatar
podgeywodgey23
Question Much Difference ?
How much difference does a high lift cam give a CVH FRST ?And does it matter whether its a newman cam or kent cam ?
Old May 23, 2008 | 07:59 PM
swerv's Avatar
swerv
i wouldnt let a piper or kent near my engine, the quality is really awfull, well it was a few years ago, not sure if they use better blanks.
newman use good quality blanks as far as i know.
not sure if you will see that much benefit, the standard cam is good for around 200hp or so
Old May 24, 2008 | 06:19 AM
There is nothing at all wrong with either PIPER or KENT, they are both excelelnt quality.
The piper 285T profile gets some rave reveiws, most cams are killed by not being bedded in correctly, I alywas use REGRINDS, never ever blanks.
Old May 24, 2008 | 08:52 AM
benreader's Avatar
benreader
just taken a kent cvh35 out of my escort, was brilliant for around 10mins! seriously though, it lasted less than 12months, was fucked after about 3000miles. iv just put the original back in, not too much difference mate.
Old May 24, 2008 | 09:01 AM
grayzo's Avatar
grayzo
grayzo
newman cams are the daddy
Old May 24, 2008 | 09:19 AM
benreader's Avatar
benreader
yeah iv been told since go with a newman cam, much better blanks, harder wearing
Old May 24, 2008 | 03:59 PM
swerv's Avatar
swerv
rubbish, the quality is poor, agreed the profile of the 285T is good and would probably have one in mine if would last more than 12 months!!
if you care for your engine why would you fit a shit cam?
Old May 24, 2008 | 04:02 PM
swerv's Avatar
swerv
they are only more hard wearing if you 'work harden' them properly when running in.
Old May 24, 2008 | 04:54 PM
©hatter Box's Avatar
©hatter Box
i had a few kent 35 cams one last 3 years other one lasted 5 miles
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
