HUBS - 3dr/2wd/4x4 what's the difference?
Old May 22, 2008 | 07:10 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Default HUBS - 3dr/2wd/4x4 what's the difference?
Had some 2nd hand hubs fitted a while back, just want to check I was fitted with the right ones. What are the differences between the 3dr hubs and Saff? Are RWD and 4x4 Saff the same or different? etc.
Thanks in advance
Old May 22, 2008 | 07:31 PM
Moonstone Mart's Avatar
Moonstone Mart
I have been told that there is a difference between the 3dr and 2wd saph front hubs. Its something to do with the lenght/height/angle of the hole for the TCA's and the pivot arm for the steering rack.
I think Mike rainbird noted it on a post a while back.
The diff between all 2wd and 4wd front hubs is the offset, rears are the same as far as i know.
Someone else should be along pretty soon with a better explanation and to correct me no doubt .
Mart.
Old May 22, 2008 | 07:49 PM
Ryan's Avatar
Ryan
easy way to tell between 2wd and 3dr hubs.
2wd hubs use a pinch bolt system for the TCA joint. (so the bottom part is split)
3dr hubs use a castle nut for the TCA (so bottom part is solid)
4wd hubs will have a different drive flange as they need a drive shaft to go in them, so its pretty damn obvious if they have
Hope this helps.
Old May 23, 2008 | 05:42 PM
rinus_2005's Avatar
rinus_2005
hmm my cossie 3door came with pinch bolt system? probably replaced for 2wd(sedan) ages ago
Old May 24, 2008 | 11:31 AM
oohogwash1's Avatar
oohogwash1
And the RS500 front hubs have a lower TCA mount point, it helps keep them aligned correctly when they are in running trim. It is quite noticable if you have two side by side.
Old May 24, 2008 | 12:33 PM
AndyPen's Avatar
AndyPen
I didn't think that there was any difference between a 3 dr and an rs 500?? Will have to go check my book tonight
Old May 26, 2008 | 05:31 AM
oohogwash1's Avatar
oohogwash1
I have one of each here... roll centres are different... I didn't think there was any difference either till one day I found out and so I hunted and found these. I can double check with a friend he has both 500 and normal RS... if I see both cars together I can check them out...
Old May 26, 2008 | 11:56 AM
AndyPen's Avatar
AndyPen
Interesting - have just been through the complete Unique Service Parts list and subsequent Technical Bulletins and found no reference - any chance of a pic mate?
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
fordrallycar
Sep 30, 2015 07:57 PM
SMILER258
Sep 28, 2015 09:04 AM
little bram
Sep 27, 2015 07:45 AM
